Originally posted by drozwood90
View Post
New HSTouch Server Plug-in Released v 1.0.0.50
You can just re-install the previous version I believe. I have gone from .45 to .44 back to .45 and now to .50.
BTW though I didn't see any issues with .49 yesterday or .50 today as far as I could tell.- Pete
Originally posted by rmasonjr View PostI think I'll just revert back until this is fixed or there are more docs on how to use the new service.
Guest
Tried this and not getting any weather data. api key is entered on the HSTouch screen and location is set.
Anything else required?
PHP Code:21/02/2012 08:03:09 HSTouch Server Debug 08:03:09:0937 ~ Checking RSS url: 21/02/2012 08:01:01-http://free.worldweatheronline.com/feed/weather.ashx?q=$LATITUDE,$LONGITUDE&format=xml&num_of_days=5&key=$WEATHERAPIKEY
21/02/2012 08:03:19 HSTouch Server Debug 08:03:19:0937 ~ Checking RSS url: 21/02/2012 08:01:01-http://free.worldweatheronline.com/feed/weather.ashx?q=$LATITUDE,$LONGITUDE&format=xml&num_of_days=5&key=$WEATHERAPIKEY
21/02/2012 08:03:29 HSTouch Server Debug 08:03:29:0937 ~ Checking RSS url: 21/02/2012 08:01:01-http://free.worldweatheronline.com/feed/weather.ashx?q=$LATITUDE,$LONGITUDE&format=xml&num_of_days=5&key=$WEATHERAPIKEY
Mark,
How about a little teaser?
Is there anything else in the imminent release of designer besides the new weather feed? IE. Any other bugs fixed?
As it is I've managed to work around the international weather issues using the existing plugin/designer. If this is the only improvement, there's really no need for me at this point to tamper with things.Real courage is not securing your Wi-Fi network.
Originally posted by macromark View PostRob - no need to revert back. Your existing project should work fine as is. I will post a new project soon that includes the new code. Rich will also be releasing a new designer (maybe tomorrow) that includes the new feed to make it easier to work with.HS4Pro on a Raspberry Pi4
HSTouch Clients: 1 Android
Originally posted by 8r1an View PostTried this and not getting any weather data. api key is entered on the HSTouch screen and location is set.
Originally posted by rmasonjr View PostMy existing projects come up with New Hampshire as the location. This happens on a custom project (windows) that uses api.wxbug.net rss feeds with the [$ZIPCODE]. I also tried the stock app on my kindle fire and got the same thing.
Can someone help me to set up the weather tool.. I dont get it too work.
If i try to push the current buttom i got this msg "21.02.2012 19:13:04 - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer HSPRO\html/Images/weathericons/condition/"
Is the a guide how too setup the weather and are the a "ready to use" "site" i can use on my ipad.Last edited by Mrtiger; February 21, 2012, 01:22 PM.
Originally posted by macromark View PostRich identified the problem and is creating a new build to fix this .51. I'll post as soon as its built.
ftp://ftp.homeseer.com/pub/HomeSeerP...h_1_0_0_51.msi
HSTouch works for a while and then no longer allows ANY client to connect until HomeSeer is restarted. This was tested with 2 iPads, iPhone, iPod Touch and Windows client....
If you want a network trace I can email it to you. Essentially, the client connects but HSTouch doesn't respond. After a few minutes the client timesout.
If HomeSeer is restarted, then it works for a while and does the same thing.
Since this is not the first time situations like this have been reported with HSTouch, can we please get some advanced debugging so that we can assist in tracing down the root cause?
The little of debug that exists doesn't appear to go very deep in terms of troubleshooting this. But, I would be happy to provide any logging that you want.
Application plugins in this case shouldn't impact HSTouch in this situation. If so, then PLEASE have HSTouch run as a separate application so that it can be killed and restarted without having to restart HomeSeer.HomeSeer 2, HomeSeer 3, Allonis myServer, Amazon Alexa Dots, ELK M1G, ISY 994i, HomeKit, BlueIris, and 6 "4k" Cameras using NVR, and integration between all of these systems. Home Automation since 1980.
Want Weatherbug data in HSTouch
I saw that Weartherbug has been redirected to worldweatheronline (My Server Version: 1.0.0.51), but that we should still be able to use Weatherbug data. How do we go back to Weatherbug? I updated a project, and now the weather icons are different, and a lot of data is missing - Today's forecast, %Light, Hi/Low Temp/Humidity for the day, rain totals for the day....etc.
Here are some examples that longer work, but refer directly to Weatherbug:
[$RSS=http://api.wxbug.net/getLiveWeatherRSS.aspx?ACode=A5679336775&zipcode=46229&unitt ype=0->gust-speed->gust-speed_Text->0] MPH Gusts
[$RSS=http://api.wxbug.net/getLiveWeatherRSS.aspx?ACode=A5679336775&zipcode=46229&unitt ype=0->rain-today->rain-today_Text->0] " Rain Today
[$RSS=http://api.wxbug.net/getLiveWeatherRSS.aspx?ACode=A5679336775&zipcode=46229&unitt ype=0->ob->light->0]% Light
