Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Hardware > Z-NET
Z-NET Discussions about HomeSeer's Z-NET IP-Enabled Z-Wave Interface
Old December 22nd, 2015, 12:44 PM
kevini kevini is offline
Cannot access Z-wave settings for GE/Jasco modules on Beta of Z-wave plugin
When I try and access the Z-wave settings on GE/Jasco modules the operation times out (I get left with an empty Z-wave pane). I also see this in the log:
Dec-22 8:41:52 AM Error Calling ConfigDevice in plugin Z-Wave:Object reference not set to an instance of an object.
Dec-22 8:41:55 AM Error Calling HSEvent in plugin Z-Wave, Instance :Object reference not set to an instance of an object.
This is on 3.0.1.54 beta. If I downgrade to 3.0.1.25 it works fine.
Old December 22nd, 2015, 01:14 PM
prnorton prnorton is offline
I just tried this, and mine works fine with the latest beta. Wonder if it would help to clear your browser cache or history.
}{ Phil }{
Old December 22nd, 2015, 01:18 PM
I'll give it a try. I tried 2 different modules. I'll try on a different PC too.
Old December 22nd, 2015, 01:26 PM
Definitely not the browser. Once I try and access from the settings I can't even see the Z-wave tab for that device. No problems on the released version.
Old December 22nd, 2015, 01:31 PM
Rupp's Avatar
Rupp Rupp is offline
I wonder if the device is missing something that the new beta is looking for. Can you try recreating the device with the beta and see if it works?
-Rupp
Old December 22nd, 2015, 01:40 PM
I removed and re-added the device with the beta and saw the same issue.
It does seem like some setting must be missing with these devices based on the error.
Old December 22nd, 2015, 03:05 PM
Rupp's Avatar
Ok, thanks. I wonder if it's a firmware thing?
Old December 22nd, 2015, 03:09 PM
Could be, these are the full details on the node:
Network and Node ID 003D236E, 16 Manufacturer Jasco Products (ID=0x63) Product Type 0x5250 Product ID 0x3130 Node Name from Node Christmas Node Location from Node Living Room Node Type GENERIC TYPE SWITCH BINARY Supports Status Yes Library Type Routing Slave Z-Wave Lib Version 2.64 (ZDK 5.02.2 Patch 2) Application Version 1.16 Command Class Switch Binary Command Class Version 1 Next Poll Time and Failures 11:26 AM / 0 Neighboring Nodes 13 Neighbors: 1, 3, 4, 6, 7, 9, 11, 12, 13, 19, 20, 22, 26
GE Jasco Switches and Z-Wave doorlocks djdzam HomeSeer General Discussion Area 1 June 29th, 2012 04:17 PM
GE/Jasco Z-Wave Model 45606 switch question Blade HomeSeer Z-Wave Plug-in 10 January 10th, 2011 05:22 PM
Jasco/GE Z-Wave Thermostat? The Keeper HomeSeer Z-Wave Plug-in 4 November 18th, 2010 02:29 PM
GE Jasco Z-Wave Switches Blade HomeSeer Z-Wave Plug-in 5 October 28th, 2010 11:34 PM
Jasco Z-Wave Product Line Preview Konway HomeSeer Z-Wave Plug-in 4 January 5th, 2008 02:14 PM
