BLUSBUIRT 2.0.9.0 Didn't send IR - Fixed!
    I noticed that the newer BLUSBUIRT 2.0.9.0 was available as a normal update for HS3 so updated over my existing 2.0.7.0.
    It broke my IR control
    The USB-UIRT would receive IR, and Homeseer could start an event with it, but it did not send out any IR commands.
    For example, I use my Sky UK remote control to turn everything on - Sky satellite (direct IR), motorised screen (IR from USB-UIRT), AV amp on (IR from USB-UIRT), Projector on (IR from USB-UIRT) as well as a lot of interspersed z wave power on commands. The z-wave commands all worked, but the IR didn't work from the USB-UIRT.
    I have now reverted it to 2.0.7.0 and all is well. Any ideas ?
    Win 11 Pro | HS4 Pro | Z wave plug in with UZB1 | BLUSBUIRT 2.0.11.0 | RFXtrx433 | Blue Iris CCTV | VU+ 4k with motorised dish | Emby | Hi-Phone HS2 | ESP32 with WLED |
    Can u capture a debug log of it and attach it zipped
    Cheers,
    Bob
      Hi, i'll do it over the weekend since I have reverted to 2.0.7.0.
      I did a little bit of testing at the time:
      1. Events looked OK.
      2. Settings in the plug-in didn't appear to have anything new to stop it working.
      3. Manually pressing 'Send' in the plug-in did send the IR commands.
      4. There were no messages in the main log to show any failures when the event ran - it did show the z-wave devices in the sequence.
      It's just that IR wouldn't work in an actual event - or when the event was triggered manually.
      So to clarify, you need me to run 2.0.9.0 with BLUSBUIRT / Options / Debug-logging on, and run the event ? Then send the main log ?
        I am sure I can figure it out quickly once I see the debug log
        Cheers,
        Bob
          Well I re-installed 2.0.9.0 and again it doesn't work for me.
          1. Install 2.0.9.0
          2. Turn off BLUSBUIRT plug in.
          3. Restart HS3.
          4. Enable debug logging.
          5. Check SKY event - all z-wave devices work, but no IR control.
          6. Turn off debug logging.
          I found the detailed BLUSBUIRT log file, and have attached it to this post.
          The normal log file doesn't show anything interesting:
          Nov-07 14:10:41 BLUSBUIRT Info BLUSBUIRT Debug Logging Disabled!
          Nov-07 14:10:33 Z-Wave Device: Ground Lounge Projector Screen Power Set to 0
          Nov-07 14:10:33 Event Deleting event after run: "Delayed Actions Projector Screen Power (Delayed Action) - 2"
          (System)_07-Nov-2014 14:07:35.3518_Event Handler
          Nov-07 14:10:33 Device Control Device: Ground Lounge Projector Screen Power to Off (0)
          Nov-07 14:10:33 Event Event Trigger "Delayed Actions Projector Screen Power (Delayed Action) - 2"
          Nov-07 14:10:08 Device Control Device: Ground Lounge Lounge Top to Off (0)
          Nov-07 14:10:08 Device Control Device: Ground Lounge Subwoofer power to On (255)
          Nov-07 14:10:03 Z-Wave Device: Ground Lounge Projector Screen Power Set to 255
          Nov-07 14:10:03 Device Control Device: Ground Lounge Projector Screen Power to On (255)
          Nov-07 14:10:03 Device Control Device: Ground Lounge Projector power to On (255)
          Nov-07 14:10:03 Event Event Trigger "Sky ON Sky ON"
          Nov-07 14:09:02 BLUSBUIRT Info BLUSBUIRT Debug Logging Enabled!
          And I cannot see any BLUSBUIRT activity there other than starting and stopping debug logging
            I see the issue.
            Once I am home this afternoon I will fix it and get a new build in the updater and get you to try it out.
            I will reply here once done
            Go back to 2.0.8 until I release 2.0.10
            Cheers,
            Bob
              Thanks for letting me know. I will test it as soon as I see it. It gets a lot of use here !
              Tim
                Should be done shortly
                Cheers,
                Bob
                  OK try 2.0.10 in the updater and let me know
                  Cheers,
                  Bob
                    Hi Bob,
                    2.0.10.0 is working well. IR control is restored
                    Thank you !
                      What was added to the new version
                      HSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
                        I fixed the repeats not working
                        Cheers,
                        Bob
