Hi Blade,
This model has Internet radio built in. I have toggled through all the Audio inputs and not been able to have the receiver switch to it. Is it possible to add that to plugin?
Also, IF it is on that function - plugin won't select MPlay again until I 1st choose tuner...
Master Power on works - but not a discrete command as if unit is already on, it power cycles the receiver.
Was hard to find documentation on what port to use - I saw 23 on other posts, but if you listed it somewhere in your knowledge base would help or where to even look for what it might be.
