I have two RC80's and two RC100's that I've been using for a few years with HS2 with no major problems. Switching to HS3 I found this Omnistat3 plugin to be superior in design and capability (IMHO) over the Homeseer plugin. Initially I had problems with getting one of the thermostats enrolled but that problem went away. No I can read all four thermostats and I see the Outdoor temperature displayed on all four thermostats so I know the plugin can write to them successfully. The problem is I cannot control any of the parameters. If I change a Cooling Setpoint temp in the GUI it changes but then pops back to the old number a few seconds later. Likewise for changing modes or controlling anything on any of the thermostats. I checked the omnistat3 log and even though I'm changing things in the user interface I so no corresponding traffic go to the stats. I do see a constant stream of group two status requests (as would be expected) and I see each of the thermostats responding with data also. But I see no evidence of commands being sent to the stats corresponding to setting parameters.
Any thoughts would be greatly appreciated!
