Originally posted by mnsandler
View Post
HS3 Vista Alarm plugin v3.0.0.40 Beta (for Windows & Linux)
Guest
Originally posted by aaron View PostGotcha. So is there no way to change this then?
you might be able to change the count down (exit delay) or other options in your panel programming for arm-stay or arm-instant, but not exactly sure.Mark
HS3 Pro 4.2.19.5
Guest
Originally posted by mnsandler View PostI have a 20se that doesn't send count down msgs so the status changes on the first message.
Both Arm-Stay and Arm-Away count down 45 seconds on my panel...
When I use "Arm-Away", the device changes to "Armed" status in HomeSeer within 1-2 seconds after hitting the button... So when there is still 43 seconds on the panel left...
When I use "Arm-Stay", the the device doesn't change to "Armed" until AFTER the count down has completed...
So, my question is why? Why wouldn't they both switch the status in HomeSeer right away?
Please post the first panel msg received after you activate each mode and I will point out in the details why of the msg.Mark
HS3 Pro 4.2.19.5
Guest
Originally posted by mnsandler View PostPlease post the first panel msg received after you activate each mode and I will point out in the details why of the msg.
Arm-Away (Instant changed in HomeSeer)
Apr-18 4:32:07 AM Vista Alarm Setting System to Armed Away
Apr-18 4:32:07 AM Vista Alarm MessageKey=ARMED ***AWAY***May Exit Now 43 1
Apr-18 4:32:07 AM Vista Alarm Processing msg on Partition 1
Apr-18 4:32:07 AM Vista Alarm [0101050110000000----],043,[f7000087104305002c020000000000],"ARMED ***AWAY***May Exit Now 43"
Apr-18 4:32:06 AM Vista Alarm Setting System to Armed Away
Apr-18 4:32:06 AM Vista Alarm MessageKey=ARMED ***AWAY***May Exit Now 44 1
Apr-18 4:32:06 AM Vista Alarm Processing msg on Partition 1
Apr-18 4:32:06 AM Vista Alarm [0101050110000000----],044,[f7000087104405002c020000000000],"ARMED ***AWAY***May Exit Now 44"
Apr-18 4:32:05 AM Vista Alarm Setting System to Armed Away
Apr-18 4:32:05 AM Vista Alarm MessageKey=ARMED ***AWAY***May Exit Now 45 1
Apr-18 4:32:05 AM Vista Alarm Processing msg on Partition 1
Apr-18 4:32:05 AM Vista Alarm [0101050110000000----],045,[f7000087104505002c020000000000],"ARMED ***AWAY***May Exit Now 45"
Apr-18 4:32:05 AM Vista Alarm Setting Partition 1 to Armed Away
Apr-18 4:32:05 AM Vista Alarm !Sending.done
Apr-18 4:32:05 AM Vista Alarm SendingCode:+2 Apr-18 4:31:58 AM Vista Alarm Setting System to Disarmed-Ready
[CODE]
Apr-18 4:33:46 AM Vista Alarm MessageKey=ARMED ***STAY***May Exit Now 43 1
Apr-18 4:33:46 AM Vista Alarm Processing msg on Partition 1
Apr-18 4:33:46 AM Vista Alarm [0011000110000000----],043,[f70000871043008028020000000000],"ARMED ***STAY***May Exit Now 43"
Apr-18 4:33:45 AM Vista Alarm MessageKey=ARMED ***STAY***May Exit Now 44 1
Apr-18 4:33:45 AM Vista Alarm Processing msg on Partition 1
Apr-18 4:33:45 AM Vista Alarm [0011000110000000----],044,[f70000871044008028020000000000],"ARMED ***STAY***May Exit Now 44"
Apr-18 4:33:44 AM Vista Alarm MessageKey=ARMED ***STAY***May Exit Now 45 1
Apr-18 4:33:44 AM Vista Alarm Processing msg on Partition 1
Apr-18 4:33:44 AM Vista Alarm [0011030110000000----],045,[f70000871045038028020000000000],"ARMED ***STAY***May Exit Now 45"
Apr-18 4:33:44 AM Vista Alarm Setting System to Disarmed-ReadyLast edited by mnsandler; April 18, 2017, 07:50 AM.
Guest
Not sure why that didn't post correctly Sorry about that...
Bottom line, you never see "Setting Partition 1 to Armed Stay" when you use the Armed-Stay function. I think this is the problem. But I'm not sure why we wouldn't see that since it really does it on the panel.
I believe the issue is related to your garage door (zone 16). the panel isn't reporting (no faults) and thus the plugin isn't responding as expected (ie setting the arm-stay status)Mark
HS3 Pro 4.2.19.5
Guest
Originally posted by mnsandler View PostI believe the issue is related to your garage door (zone 16). the panel isn't reporting (no faults) and thus the plugin isn't responding as expected (ie setting the arm-stay status)
And again, it works for Armed-Away, just not Armed-Stay.
So are you telling me on your system, if you click "Armed-Stay", your status changes within 1-2 seconds from clicking the button? It's just mine that doesn't?
Originally posted by aaron View PostSo are you telling me on your system, if you click "Armed-Stay", your status changes within 1-2 seconds from clicking the button? It's just mine that doesn't?Mark
HS3 Pro 4.2.19.5
I see with the new beta, that you have changed formatting on the last panel display message.
Personally I prefer having the spaces in there as it makes the message more intelligible and mimics the panel. Also I have many events that trigger based on certain messages and retooling these would be quite extensive.
Could you please add a configuration to either through the plugin configuration or manual INI modification to format keep the old way you displayed the last panel message?
Reverting this change or making an option to use the prior format would be greatly appreciated.
Originally posted by skarragallagher View PostI see with the new beta, that you have changed formatting on the last panel display message.
Reverting this change or making an option to use the prior format would be greatly appreciated.Mark
HS3 Pro 4.2.19.5
Field *197 enables the countdown display. When this field is 0, the countdown isn't displayed and the System Status and Partition 1 Status devices change immediately upon arming (start of countdown). But when *197 is 1, for modes Armed-Stay, Night-Stay and Armed-Instant, both devices display "Disarmed-Ready" until the countdown expires. For Armed-Away and Armed-Maximum, the devices change state at the start of the countdown, just like when the field is zero.
I'd wager that you'll see the same if you set your *197 to 1...
Originally posted by skarragallagher View PostThat is half the issue though... Display. I will dig through my events and test though.
Sent from my XT1254 using Tapatalk
is your concern with the display related to HS Touch and not the web ui?Mark
HS3 Pro 4.2.19.5
