I am trying to setup the maintenance reminder script. I have HS 2.2.0.66 and have installed web wraper.
I installed the files Mainten.asp in the HTML folder, Maintenance.vbs in the scripts folder and the .gif files in the HTML\Images folder
I have only one reminder at this time, once I reslove this problem I will clear the ini file and load more. I have set up the refresh script, setup and clear scripts.
My HS log does not show any errors, however when I run mainten.asp I receive the following message.
Script error: Object variable or With block variable not set.
response.write Cstr( hs.plugin("Web Wrapper").Header("Maintenance & Reminders",0, False))
Any suggestions? any further info required.
Thanks in advance for your help.
Chris
Chris
