I was trying to get the battery status of the device the client is running on, so I used a visual basic script I found as the basis for this.
(it uses System.Windows.Forms )
And even though it gets the data, the data it does get is from the HS machine (which doesn't run on battery etc) - so I assume scripts are always run from the HS machine?
How would I go about getting this data from the HS touch client machine?
Cheers,
Elco
Cheers,
Elco
