I just purchased a CT30 Z-Wave thermostat from homeseer. It's installed and working, with one frustrating exception.
The instructions state that the radio will go to sleep if using only battery power. The thermostat must have the "c-wire" connected in order for the radio to remain on and receive commands from Homeseer. I have the c-wire connected (and it was in use/functional with the original thermostat in use) but the radio goes to sleep several seconds after the last "touch" to the thermostat.
I can visually see the radio active indicator on the display, and when the display and as soon as the back-light turns off, the radio active indicator turns off.
When that display is turned off, the thermostat will not accept z-wave commands from Homeseer. When the display is on and the radio indicator shows activity, the homeseer z-wave commands complete successfully every time.
The thermostat is set up with a 4-wire heat/cool connection on setting 1 (single stage), and the additional c-wire.
Thanks for the help!
Jim
Jim
