Originally posted by gelessor
View Post
BLStat beta
Polling is at 120 sec. The thermostat is a 2GIG CT30. I didn't have the debug log option checked. It is checked now and I will send you the log that gets generated. Elliott"Living with technology means living in a [constant] state of flux." S. Higgenbotham, 2023
Originally posted by gelessor View PostThe events are not working.
Under devices the thermostat is called "Thermostat 1". When creating an event it is called "z-wave Interface thermostat". New events seem to run, but nothing changes on the thermostat.
These events were working, but appear to have been broken a couple releases back - now running beta 1.0.2d
Try that and let me know
Originally posted by gelessor View PostTried creating new event -still not working
Requested log info...
HS log shows event triggered
1/3/2011 7:18:53 PM - Event - Event Trigger "Decrease heat setpoint by 1 degree"
1/3/2011 7:19:08 PM - Media Player - Warning, queued command did not complete due to timeout: player_state
1/3/2011 7:19:12 PM - X10 Received - O13 (Theater Motion) O On
1/3/2011 7:19:19 PM - X10 Received - O13 (Theater Motion) O On
1/3/2011 7:19:38 PM - Device Control - Device: Hallways Plants (F10) ON
1/3/2011 7:19:38 PM - OCCUPANCY - \ \ \ \ \ \ \ \ \ \ Alarm Upstairs Occupancy set to "Occupied" - Vacant (00:07)
1/3/2011 7:19:38 PM - MOTION - >>>>>>>> Motion Detected with Hallways Motion - No Motion (00:37)
BLSTAT Log...
1/3/2011 7:10:15 PM Information Z-Wave Interface Thermostat (1) Manufacturer: 2GIG; Model: ZSTAT CT30E
1/3/2011 7:10:15 PM Information 1 Thermostat has been loaded
1/3/2011 7:09:57 PM Information Z-Wave Interface Thermostat (1) System is now Idle
1/3/2011 7:08:53 PM Information Z-Wave Interface Thermostat (1) System is now Heating
1/3/2011 7:08:53 PM Information Polling has been activated for all thermostats
1/3/2011 7:08:50 PM Information Scheduling has been activated for all thermostats
1/3/2011 7:08:48 PM Information Z-Wave Interface Thermostat (1) Manufacturer: 2GIG; Model: ZSTAT CT30E
1/3/2011 7:08:48 PM Information 1 Thermostat has been loaded
Debug file
Blade:
Attached is part of the debug file. The error in my HomeSeer log starts at 7:51:17 PM
1/3/2011 7:52:09 PM BLStat Info BLStat Debug Logging Disabled!
1/3/2011 7:51:31 PM BLStat Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): selectQueryString: SELECT txtDateTime,txtThermostatNumber,txtMode,txtState,txtSeconds FROM tblStatData WHERE txtDateTime >= #1/3/2011 0:0:0# AND txtDateTime <= #1/3/2011 23:59:59# ORDER BY txtDateTime DESC
1/3/2011 7:51:31 PM BLStat Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): connString: DSN=BLStat
1/3/2011 7:51:31 PM BLStat Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): DatabasePathAndName: C:\Program Files\HomeSeer HS2\Data\BLStat\BLStat.mdb
1/3/2011 7:51:31 PM BLStat Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): An error has occurred during database select query: No value given for one or more required parameters.
1/3/2011 7:51:27 PM BLStat Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): selectQueryString: SELECT txtThermostatNumber,txtMode,txtState,SUM(txtSeconds) FROM tblStatData WHERE txtDateTime >= #1/3/2011 0:0:0# AND txtDateTime <= #1/3/2011 23:59:59# GROUP BY txtThermostatNumber,txtMode,txtState ORDER BY txtThermostatNumber,txtMode
1/3/2011 7:51:27 PM BLStat Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): connString: DSN=BLStat
1/3/2011 7:51:27 PM BLStat Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): DatabasePathAndName: C:\Program Files\HomeSeer HS2\Data\BLStat\BLStat.mdb
1/3/2011 7:51:27 PM BLStat Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): An error has occurred during database select query: No value given for one or more required parameters.
1/3/2011 7:51:21 PM BLStat Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): selectQueryString: SELECT txtDateTime,txtThermostatNumber,txtMode,txtState,txtSeconds FROM tblStatData ORDER BY txtDateTime DESC
1/3/2011 7:51:21 PM BLStat Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): connString: DSN=BLStat
1/3/2011 7:51:21 PM BLStat Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): DatabasePathAndName: C:\Program Files\HomeSeer HS2\Data\BLStat\BLStat.mdb
1/3/2011 7:51:21 PM BLStat Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): An error has occurred during database select query: No value given for one or more required parameters.
1/3/2011 7:51:17 PM BLStat Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): selectQueryString: SELECT txtThermostatNumber,txtMode,txtState,SUM(txtSeconds) FROM tblStatData WHERE txtDateTime >= #1/3/2011 0:0:0# AND txtDateTime <= #1/3/2011 23:59:59# GROUP BY txtThermostatNumber,txtMode,txtState ORDER BY txtThermostatNumber,txtMode
1/3/2011 7:51:17 PM BLStat Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): connString: DSN=BLStat
1/3/2011 7:51:17 PM BLStat Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): DatabasePathAndName: C:\Program Files\HomeSeer HS2\Data\BLStat\BLStat.mdb
1/3/2011 7:51:17 PM BLStat Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): An error has occurred during database select query: No value given for one or more required parameters.
ElliottAttached Files"Living with technology means living in a [constant] state of flux." S. Higgenbotham, 2023
Bob,
I am getting ready to write an ASPX page to graph the daily run-times for the HVAC system, and I have a quick question for you: I took a look at your database, and I *THINK* I should be able to walk through and compute the times between "System is now Heating" and "System is now Idle" activity entries. Does that sound right?
Also: It looks like some of the earlier Betas were not logging the Idle event. Is that true? As long as it logs it now, I'll be fine. If there is some other situation where it doesn't log idle, my plan is busted.
Thanks again for a great PI.
Steve
