Put this question in its own thread. How could this work for my needs?
I am looking at configuring the upstart file so the locations of my devices fall into 3 locations, (not UPB Device Link) location.
interior
outdoor
holiday
How can I do this?
That way when HS reads the config file.... no changes are to be made that messes up the UPB plugin.
Hope this is what was explained?
I am not using HS Touch just a regular HS web page. All my other HS created devices can be moved and reorganized to any location but UPB will not work with any changes when they are changed at HS web side. Feature Request - that should be locked since the device will not be able to be controlled if you change this location parameter.
Here is an example:
Status Location Name Code Last Change Control
None UPB Device Link White Lights ON/OFF &13 12/9/2010 6:23:31 AM
If I change the - UPB Device Link - to any other location, such as interior,
HS will not be able to control them and in fact they have a mind of their own.
Thanks.
interior
outdoor
holiday
How can I do this?
Here is an example:
Thanks.
