Can confirm the above
CT30 and Celsius
Strangly, after a few resets, suddenly it's possible to set the cool and heat setpoints on HS touch albeit indeed only at in/decrements of 1 degree.
but there are a few other bugs:
1) manual changes on the ct30 itself are not reported back to homeseer i.e. they are not synchronized.
2)after a reset/restart of homeseer the cool setpoint is always set to 0 degrees i.e. it is not read back from the CT30 correctly
3) the min/max for F/C table in the thermostat.ini is not taken in account, ie it only looks at the F value,only after changing this table it is possible to script values below 40 degrees (essential if you don't want to be cooked ;-) )
(what is the use of this table anyway ?)
4) In HStouch Designer , setting the setpoint with a button is still only possible with the min/max values for Fahrenheit , not the "new" min/max values for Celcius
edit 2) solved , after changing the min / max values for Fahrenheit in "logical values" voor Celcius, both setpoints, cool and heat , can be set and are displayed correctly
@Paul, this should solve your problem tooLast edited by ceesmf; July 22, 2011, 09:14 PM.
Further to my earlier message about the Thermostat device showing 1 decimal place - when I look at the Thermostat Root device, the current temp is shown to one decimal place, but the set point is shown rounded - ie. Currently my thermostat is set to 21.5 C for a setpoint, but my Thermostat Root device shows the Temp as 21.9, and the setpoint as 22....
@Paul
The exact name of the ini file is "ZWAVE Thermostats.ini" and should be in your config subdirectory
I think it is installed at the initial homeseer install
I changed it to this: (obv. only the first two values are taken in account)
[Settings]
gAbsMinTempF=10
gAbsMaxTempF=50
gAbsMinTempC=10
gAbsMaxTempC=50
gDebug=True
gZWErrorsDisabled=False
Ok, found out why I couldn't find the ini file - the Zwave Thermostat plugin was disabled - I never enabled it because my understanding was that with current versions of HS the Zwave thermostat stuff was built in, and indeed it's been working (with the above exceptions in mind) without the plugin enabled.
I enabled the pluging, altered the config, and indeed the ini file appeared. However appropriately doctoring the F side of things as you suggested didn't help - I still can't set my setpoint from HS Touch on my iPhone...
@Paul
Im not able to set a setpoint either but when I run the iphone client as a windows client(deployed as a windowsclient), with no changes, I can. It also is not possible as an android client; so this must be a hs-touch bug; all setpoint commands, heat-, cool- en incr/decrease dont work but on/off/cool/heat works
Setting the setpoints on the plug-in webpage does however work and setting the setpoint via an event isn't a poblem either
Hi Rich, sorry, didn't work. I still can't change setpoints from the Climate screen on my iPhone when in Celsius. Just to double check, I changed to F, restarted HS, and was still successful in changing the setpoint while in F. Then I changed back to C, restarted, and setpoint changes stopped working from my iphone again.
Paul
