Control Channel with script via plugin
    Spud,
    sorry to bug again, but is there a way to call the channel function via a script?
    Im creating a script for for the Kinect plugin and need to pass the channel to the remote device or a function in the plugin. I could pass it via url directly to the directv I guess but that would defeat the use of the plugin
    Let me know if this is possible or you have a better way
    Something like this (not complete just a flow):
    VSource = hs.GetVar("kinectvar0")
    If Vsource = "Fox" Then
      channelnum=4
    ElseIf Vsource = "NBC" Then
      channelnum=5
    ElseIf Vsource = "ABC" Then
      channelnum=8
    ElseIf Vsource = "CBS" Then
    etc...
    hs.PluginFunction(DirecTV, "", "Change_Channel", channelnum)
    Steven G
    yes that's possible.
    there are two (undocumented) functions available by script:
    public void SendRemoteKeyCmd(string key)
    public void SendTuneChannelCmd(int channel)
    I will add some examples in the User Guide
      Did you have a chance to update the user guide? Only reason I ask is the User Guide page was updated but I did not find any new information, just wanted to make sure I was not missing it or looking at wrong guide
      Steven G
        I haven't updated the user guide yet, but here is a simple example script to tune to channel 33:
        Sub Main(ByVal parm as object)
            hs.PluginFunction("DirecTV", "", "SendTuneChannelCmd", New Object() {33})
        End Sub
          That worked thank you
          Steven G
