can't access my access database anymore
    I had running a asp script in HS.1.7 wich was using an access database.
    Now I have installed HS2, it won't run anymore.
    The error message is:
    Script error: Object doesn't support this property or method: 'Server.CreateObject' Set adoCon = Server.CreateObject("ADODB.Connection") adoCon.open "dsn=homeautomation"
    If I switch back to HS1.7 it run ok again. (So nothing is changed in the ODBC settings).
    Can someone help me please.
    Iris
    Same Problem
    I am having the sam problem with asp on HS2.
    Set hs = Server.CreateObject("HomeSeer.Application")
    Have you solved your problem yet
      Reading some of the threads on this issue, may have something to do with dcom settings. Made recommended changes to dcom settings, didn't help
        You now need to use the following to create the homeseer application object.
        Set hsi = CreateObject("homeSeer2.application")
        hsi.Connect()
        Set hs = hsi.GetHSRef
          As usual Rupp you are right on! worked like a charm! Thank you
            Excellent and your welcome.
            Greg
              Ok, to go back to the original question in this post, before it was hijacked to something different. seeing as I'm now having the same problem as irisk.
              How do we get an ADODB connection in the web server in HS2????
              i originally had this code
              Set cnnSimple = Server.CreateObject("ADODB.Connection")
              tried changing it to look somewhat like Rupp's answer to the following
              Set cnnSimple = CreateObject("ADODB.Connection")
              cnnSimple.Connect()
                Wes,
                Drop the server. from the create object statement and it should work with HS 2.0. I'm not sure why though. The object should be created using the server asp object.
