It works now, the weird thing is that http://connect.insteon.com/getinfo.asp still shows 1016.
Jun 19 Insteon HUB update 1016 will break the plugin
Originally posted by claude View PostI believe it was said in a previous post by Mark Sandler that the rollback to 1015 would be labeled as 1016
Says 1016 and still, nothing works.
Their customer service SUCKS!HomeSeer Version: HS3 Pro Edition
Operating System: Microsoft Windows 10 Pro
Processor Type and Speed: i7 - 3.26 GHz
Total Physical Memory: 16Gig
Plugins: BlBackup | EasyTrigger | FitbitSeer | HSTouchServer | Insteon | WeatherXML
Originally posted by papapitufo View PostIt works now, the weird thing is that http://connect.insteon.com/getinfo.asp still shows 1016.
1016 Firmware Direct Command Issue
I send the the Email to Insteon with the information yesterday around 5 pm (Sat, Jun 24). Nothing has changed yet and it's around 8 am (Sun, Jun 25). Do they work over the weekend?
Light control, thermostat control, water sensors... all not working .
from the getinfo.asp page, if you click the local ip address link at the top, and login with the credentials on the bottom of the hub you will see something like
Firmware:1015 Build Jun 20 2018 15:40:43Mark
HS3 Pro 4.2.19.5
Originally posted by GreatWhiteDan View PostAfter all of this, yesterday my hub died on me. Pretty coincidental, that they push a rollback to me, and the thing dies completely. No lights, no sound, just does nothing.
Just my luck I guessMark
HS3 Pro 4.2.19.5
Just my luck I guessLast edited by automateme; June 24, 2018, 05:19 PM.
Originally posted by GreatWhiteDan View PostAfter all of this, yesterday my hub died on me....
"If your Insteon Hub model 2245-222 has stopped working (no LED on front of the hub), Insteon will either repair or replace it, even if it's past the 2-year warranty - restrictions may apply. Please follow these steps to take advantage of this service..."
I bolded the relevant text myself. Here is a link to the post with full instructions.
Link to Insteon forum sticky
They replaced my first hub, no questions, very easy.
randy
Originally posted by randy_h View PostIn addition to the great advice from Mark and Aotomateme, the insteon forum has a sticky that reads,
randy
Originally posted by mnsandler View Postclaude,you need to send an email with the correct information to support@
please see post #146 here
Mark,
I submitted my request but have not heard back from them. Can you submit my request also?
4B:72:F2
All, Thank you for the information you all have gathered and put into this post.
