Maybe just maybe...
Homeseer 2.x install dependant in Homeseer 1.x install
KLS
Tags: None
Hello,
There is a simple fix. Uninstall HS 1.x, then install HS 2.1 in a new folder. You can copy over any items from the 1.x install. All COM plugins are registered to a specific folder, so you can't delete them, or move them manually. Hence one of the reasons Microsoft has dropped COM in favor of .NET.
When you uninstall 1.7 it will not remove any files that you updated. Backup the entire 1.7 folder just in case something does get removed.
The reason you cannot delete any files is because the Windows installer is monitoring the folder and it won't allow you to delete anything.
The 2.1 installer only installs required system files, not any plugins. So you can manually remove files after installing 2.1. Use the 2.1 updater to install any required plugins. Hope this makes sense.
KLS
KLS
Forgive me for my rant!
Rupp, its called TV, you know one of those things that looks like a computer but doesn't have a keyboard or mouse?Over The Hill
What Hill?
Where?
When?
I Don't Remember Any Hill
Virtualized Server 2k3 Ent X86 Guest on VMWare ESXi 4.1 with 3 SunRay thin clients as access points - HSPro 2.4.0.48 - ZTroller - ACRF2 (3 WGL 800's) - iAutomate RFID - Ledam - MLHSPlugin - Ultra1wire - RainRelay8 - TI103 - Ultramon - WAF-AB8SS - jvESS (11 zones) - Bitwise Controls BC4 - with 745 Total Devices - 550 Events - 104 scripts - 78 ZWave devices - 42 X10 devices - 76 DS10a's 3 RFXSenors and 32 Motion Sensors
