Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Ultra Scripts and Plug-Ins > UltraLog HSPI
UltraLog HSPI Discussion area for the UltraLog, HomeSeer database logging plug-in.
Old June 20th, 2007, 08:46 PM
Ultrajones's Avatar
Ultrajones Ultrajones is offline
UltraLog HSPI - Feature Requests
Post your feature requests here.
Outstanding feature requests:
  • Convert web page to ASP.Net (ASPX) [Complete]
  • Adjustable page size [Complete]
  • Calendar popup on filter date range [Complete]
  • Support for regular expressions to trigger events [Complete]
  • Prevent guest access [Complete]
  • Retry/Reconnect DB logic [Complete]
  • Support for MySQL 5 [Complete]
  • Support for SQLite [Complete]
Old October 3rd, 2007, 12:40 AM
Wadenut's Avatar
Wadenut Wadenut is offline
For the most part, I'm quite happy with UltraLog.
One suggestion would be a drop down list for selection of the filter range; at least for the date range. Typing in a date/time is a bit cumbersome.
Another: I just wound up having to reinstall the plugin after noticing that the database had been corrupted a couple of weeks ago. Deleting the database files and restarting HS didn't do the trick. How about a DB repair/replace option.
Old November 19th, 2007, 08:03 PM
Wadenut's Avatar
Hmmm. Am I the only nit picker around???
I've just noticed that Ultralog is wide open to Guest access. Any way to limit this or is this another suggestion?
Old December 12th, 2007, 05:31 PM
Ultrajones's Avatar
My HomeSeer wouldn't allow guests access to any of my plug-ins. However, I can see value in an additional check. Please try the version I just uploaded to the HomeSeer update. It adds an option to allow guest, local or normal user roles access to the plug-in (admin is always allowed).
Ultrajones
Old May 6th, 2010, 10:49 AM
madmax's Avatar
madmax madmax is offline
SQlite?
It looks like you're embracing support of SQLite in your other programs. Have you considered adding support in Ultralog? Also, do you know what the performance differences would be between SQlite vs mysql?
Old May 6th, 2010, 08:58 PM
Ultrajones's Avatar
Definitely. SQLite uses a lot less resources (no database server to setup or configure). Performance can be pretty much the same assuming proper MySQL database format and indexing.
Ultrajones
Old June 4th, 2010, 08:28 PM
Ultrajones's Avatar
UltraLog version 1.2.3807.36079 was posted which adds support for SQLite.
Ultrajones
Old June 5th, 2010, 09:15 PM
madmax's Avatar
Working great so far. Thanks!
Old October 13th, 2010, 02:53 AM
jeroenkl
Guest
Posts: n/a
I'm happy as well with this very usefull plugin, but..
...to have my charts/graphs (MySQL>PHP>JPgraph) working as I wish to have it, I need to have MySQL log's triggered on time based instead of status/value changes only.
This will help me to create multi-line device status/value graph's with nice x-as time/date values.
Is this feature possible to add?
(like, log every x minutes device values)
many thanks,
jeroenkl
Old December 8th, 2010, 04:46 PM
C.Ligthart C.Ligthart is offline
UltraJones,
Do you have any ideas on the implementation of the time base options from the previous post?
I would be a great addition to have the device values / status written to the database on a time interval (couple of minutes).
Maybe two new options:
- Log Device Status On Interval: None, 1,2,3,5,10,15,30,60 minutes
- Log Device Value On Interval : None, 1,2,3,5,10,15,30,60 minutes
I would help as a lot when we want to create charts from the data in the database.
Oh, an other think I noticed is that I can't select an retention period greater that 24 months. Maybe you can add an "unlimited" option.
C.Ligthart
Old December 8th, 2010, 10:39 PM
Ultrajones's Avatar
Yes, I know what is required to implement, but have not had time to do so. So, add an option like Realtime, None, 1,2,3,5,10,15,30,60 minutes?
Ultrajones
Old December 9th, 2010, 02:33 PM
Thanks, for the quick reply
It enough to know that it's on your list, and that it's just a matter of time.
Thanks for this great plugin!!! and for all the work (and hours) you already spend writing it,
Cor
Old December 7th, 2011, 01:30 PM
pbibm's Avatar
pbibm pbibm is offline
Automatic Compact/Repair
Hi UltraJones
My new HS Server is a separate server with no MS Office. I keep my UL DB file as an MDB. What would also be helpful is autmating the Compact/Repair script method so that the compact/repair could happen with the purge schedule and the database stays trim and responsive.
Could a checkbox be added to options, either under Access DB Options to say "Automatically Compact / Repair when purging records"?
The functionality is:
  • If Purge is scheduled
    • Purge records
    • If the compact box is checked
      • Close the db
      • run the jet compact method
      • Open the db
  • Log the above activities.
Thanks in advace for considering this.
Paul
Old December 28th, 2011, 08:56 AM
beerygaz's Avatar
beerygaz beerygaz is offline
Super Seer
UJ - It's a year on - I just wondered if there's any progress on the timed database updates? I'd also like to char my device values and having them update the table on a fixed interval would really help.
Gaz
Old February 21st, 2015, 03:04 PM
sparkman's Avatar
sparkman sparkman is offline
Hi Randy,
I'm setting up some events to trigger on syslog entries and in some cases want to not trigger the event if the syslog entry contains a specific ip address. Would it be possible to add a Match Type "Does Not Contain" so I could use that as a condition? Alternately, is there an easy way to do it with a regular expression?
Al
Old February 22nd, 2015, 11:32 AM
Ultrajones's Avatar
Try the following regular expression. It should match provided the string does not contain foobar.
(?!foobar)
Ultrajones
Old February 22nd, 2015, 12:26 PM
sparkman's Avatar
(?!foobar)
Ultrajones
Thanks, will give that a try.
Cheers
Al
Old May 6th, 2015, 01:12 PM
Blob Blob is offline
Regex support in log search filter
Would be great if you could add regex filtering to the log viewer/search pages.
Ralph
Old July 8th, 2015, 06:10 AM
S-F's Avatar
S-F S-F is offline
Could you allow the log to be saved for longer than 12 months? I would like to NEVER purge the log of anything.
Originally Posted by rprade View Post
Old January 24th, 2016, 11:25 PM
mstrickland mstrickland is offline
SQLite DB Location
I just installed UltraLog.
Is it possible to move the SQLite DB to a different location?
If not can this be a feature request?
HTML code is On
