So I spend an abnormal amount of time in the attic. I have 1 bulb on one side of my attic. Now it's not a full height attic either and the trusses are webbed.
The one up there is one of those ceramic ones that just the bulb screws into and has a pull string. I would like this year to add more lighting so that if I do need to work up there, I can do it in the wee hours when it's still cool (I live in Florida).
So any suggestions or should I just put more of those cheap bulb bases up there ever so often?
Note: I will likely change the pull string to a switch in the main house. Since I have 2 attic accesses I'll probable do a 3-way.
Sent from my XT1585 using Tapatalk
