Homeseer 3 Pro 171 on Ubuntu 64bit Linux Wave Files
    Wondering if anybody is seeing the same as I see here relating to:
    HS3 Pro V171 on 64 bit Ubuntu Linux using
    Speaker dot exe running on a Wintel mini W2003 32bit standard OS.
    My text to speech is working just fine.
    I typically send out a wave file with my hourly clock chime.
    It doesn't play the wave file. This is the first time I have noticed this; but never really paid attention.
    I tested an event to play the wave file and the speaker dot exe log file shows that the command is going out using a Wintel path attached to a Linux path; then its getting trashed and causes an error.
    Is anyone else using a Wintel speaker dot exe connection to HS3 Pro running on Linux?
    Opening a bugzilla ticket on this today; just curious if anybody else is seeing this.
    Here is the speaker dot exe log file.
    5/13/2015 10:04:59 PM:Error playing wave file: Could not find a part of the path 'C:\Program Files\HS3 Speaker\wave_files\usr\local\HomeSeer\Media\Electronic_Chime 1.wav'.
    5/13/2015 10:04:59 PM:Wave file: C:\Program Files\HS3 Speaker\wave_files\/usr/local/HomeSeer/Media/Electronic_Chime1.wav
    5/13/2015 10:04:59 PM:Speak: The time is 10:05 PM and the outside temperature is 43.6 degrees
