Building a home and just installed around 25 Homeseer dimmers. Began setting up a few events and am running into intermittent problems. I created an even where if I triple down click either the switch at the stairs or the switch in the master bedroom it will turn off most of the lights in the house and set a few to 10% dim. Sometimes while clicking three times this works, sometimes it does not. In some cases I can triple click multiple times without it running the event, then cycle the same switch on and/or off normally, then triple click again and it will run the scene as expected. Would anyone be willing to point me in the right direction to diagnose this issue?
The main clue I have at this time is that in all cases of it not working. Cycling the switch either on or off seems to establish communication with that switch, allowing me to run the triple click scene afterwards.
