Hi
I have tried 3 video capture devices with BLCapture, a generic PCI card, a Pinnacle DV-170 and a Pinnacle TV stick. The first item doesn't work, the second items complains the Pinnacle is trying to set an unsupported video resolution and the third item sort of works but it tried to capture an image from the RF input of the card, not the composite video input I require. I will purchase a USB card specifically for BLCaputre, what would you recommend? I will connect the card to a PAL composite video camera and I want to capture a still image. I live in the UK, hence the PAL TV Standard. The card must be USB as the HS PC has no spare PCI slots.
