There are fewer weather stations that work with the Virtual Weather Station software and print out a vws file that works with your program so I wrote a little perl program that takes my Acurite weather station data and outputs it into a VWS file in the same order as my old Oregon Scientific WMR200 did. The weather data come across fine and Homeseer picks up all the information correctly.
My issue is that your software prints the following in the homeseer log every second:
Jan-13 1:10:28 PM VWS Info Data is older than 15 minutes, Check VWS
Is there a software switch (or script switch) in your program to stop this error message from being written to the log?
Or could you tell me how it is determining if the data is older than 15 minutes so I can have my perl program write the file more often with the update time information?
