I'm using BLDSC to toggle on/off the alarm chime. The virtual keypress is *>>>*
which works wonderfully to toggle the chime on/off. However, I'd like to know the existing state of the chime. If it was only turned on and off via homeseer, I could use a virtual device to keep track of it.
But if the chime is turned on or off at the keypad HS would get out of sync, and my toggle would be doing the wrong thing.
Just wondering if anyone has a work around so I can run discrete events for chime on and chime off. I tried checking the HS and BLDSC logs to see if there was anything unique recorded for on vs. off, but I saw "command acknowledge: 070" in both cases.
I'd like the chime turned off so someone coming in late at night won't wake up my household. I'd then like to turn it back on when the alarm is disarmed in the morning. I'd appreciate any ideas people have. Thanks
