Originally posted by stamatis
View Post
EnvisaLink DSC Plug-in - Feature requests
Originally posted by brientim View PostYes, exactly.
I have two panel 1864 in a single location, thus I would prefer to manage in a single HS3 instance.
click the green '+' button to create a second instance of the plugin, when you start it, you will have access to a second config page, and a second set of device will be created.
Thank you spud. That is rapid development and fantastic support. I will test later tonight when I get home (it is morning here).
A long long time ago, I started a thread which introduced you too the Envisalink and the development of this app, so it is very good to be returning to HS3 and see the evolution that has occurred since.
Removing some partitions
Hi!
Testing out the plug in with a new setup here.
Can I safely delete zones not in use? The default DSC alarm panel setup has the wireless devices starting at 20 or something, so I'd like to delete 1-19 if that's safe to do.
I'm concerned that if I restart your plug-in that it will recreate the deleted zones?
Optionally, another update might be to use a text box and parse a comma separated list rather than a pull down of zones.
i.e. instead of a pulldown selecting 27,
A box where I can enter 20,21,22,23,24,25,26,27
Any thoughts?
Any thoughts?
What you can do is hide the devices you don't use, or rename them, change their type, room, floor, so that you can easily filter them out in the device management page.
Originally posted by dmcentire View PostI appreciate the idea of an option to "not create deleted devices" that sounds pretty good.
The alpha idea doesn't work.. see snapshot below.
Out of curiosity, what language are the plug-ins written in? I'm a developer myself and might be interested in making something.
The HomeSeer SDK can be found here
http://www.homeseer.com/support/home...ng_started.htm
And, this may assist
http://forums.homeseer.com/showthread.php?t=178122
SPUD,
InstAug-29 11:39:50 AM
EnvisaLink ERROR Object reference not set to an instance of an object. Aug-29 11:39:45 AM EnvisaLink ERROR Object reference not set to an instance of an object. Aug-29 11:39:43 AM EnvisaLink ERROR Object reference not set to an instance of an object. Aug-29 11:39:41 AM EnvisaLink ERROR Object reference not set to an instance of an object. Aug-29 11:39:39 AM EnvisaLink ERROR Object reference not set to an instance of an object. Installed your plug in using a EV4. Zones show up but nothing responds.
Thanks.
