Hi guys, looking for some advice here.
I am running HS3 Pro on a windows 7 machine and have just purchased a brand new Z-NET V2 - Version 1.0.23, to upgrade from my aeontec USB Stick. As 'instructed', I backed up the USB stick network then deleted the interface and unplugged the stick. But I am having some trouble configuring the Z-NET, for some reason it does not want to accept the restore from my backup file.
HS3 always says it's successful but really it's not the Z-NET always has the 14 nodes it got delivered with and never registers the new home ID. Please help.
FYI, the Z_NET is wired straight onto the router, I can manually connect to the Z-NET webUI and see/alter the network settings. I can also successfully ping the Z-NET
Also, below are, the back up file and the log from HS when creating a new interface and trying to restore my backup. As well as what the interface setup looks like after the supposedly restore.
backup content:
HS3 Info Window:
HS3 Log:
Let me know if you require any other info. Help would be greatly appreciated.
Thank you.
Pinging 192.168.0.29 with 32 bytes of data: Reply from 192.168.0.29: bytes=32 time=3ms TTL=6 Reply from 192.168.0.29: bytes=32 time=3ms TTL=6 Reply from 192.168.0.29: bytes=32 time=3ms TTL=6 Reply from 192.168.0.29: bytes=32 time=3ms TTL=6 Ping statistics for 192.168.0.29: Packets: Sent = 4, Received = 4, Lost = 0 (0 Approximate round trip times in milli-seconds: Minimum = 3ms, Maximum = 3ms, Average = 3ms
backup content:
0161D2CC 1 1,146,22,0,2,2,0 3,210,156,0,4,16,1 4,83,220,0,4,8,6 5,210,156,0,4,32,1 6,83,220,0,4,8,6 7,83,156,0,4,32,1 8,211,156,0,4,32,1 9,211,156,0,4,15,1 10,211,156,0,4,15,1 13,211,156,0,4,32,1 14,211,156,0,4,32,1 15,211,156,0,4,32,1
HS3 Info Window:
Checking file... Starting restore operation. Restoring node information from the file C:\Program Files\HomeSeer HS3\Data\Z-Wave\ZNet_Home_0161D2CC.ZWave. Please wait... Erasing the interface... Z-Wave Interface New Interface (1) has been reset to its defaults. Erase complete - sending network ID to the controller... Restoring node information for node 1... Restoring node information for node 3... Restoring node information for node 4... Restoring node information for node 5... Restoring node information for node 6... Restoring node information for node 7... Restoring node information for node 8... Restoring node information for node 9... Restoring node information for node 10... Restoring node information for node 13... Restoring node information for node 14... Restoring node information for node 15... Node information has been successfully loaded - restarting the controller... Restore of node information COMPLETE. Done
HS3 Log:
1/11/2014 15:23 Z-Wave New Interface: Getting node information from controller... 1/11/2014 15:23 Z-Wave New Interface: The Z-Wave API Execution Thread was Started or Restarted. 1/11/2014 15:23 Z-Wave New Interface: Z-Wave Ethernet at IP 192.168.0.29, connected to interface ok. 1/11/2014 15:23 Z-Wave New Interface: The Z-Wave Command Execution Thread was Started or Restarted. 1/11/2014 15:23 Z-Wave New Interface: ---------------------------------------------------------------------- 1/11/2014 15:23 Z-Wave Initializing Z-Wave interface New Interface (HomeSeer Z-NET Ethernet) at 192.168.0.29, port 2001 1/11/2014 15:23 Z-Wave New Interface: ---------------------------------------------------------------------- 1/11/2014 15:23 Z-Wave New Interface: ====================================================================== 1/11/2014 15:23 Z-Wave New Interface: Found 14 Z-Wave nodes in interface node ID 1 (New Interface) 1/11/2014 15:23 Z-Wave New Interface: Z-Wave interface node ID: 1, Home ID: D1FE165A 1/11/2014 15:23 Z-Wave New Interface: Z-Wave Serial API version: 5 1/11/2014 15:23 Z-Wave New Interface: Z-Wave services for the SECURITY COMMAND CLASS were successfully started. 1/11/2014 15:23 Z-Wave Z-Wave network key has been updated and saved. 1/11/2014 15:23 Z-Wave New Interface: Controller firmware version: 5.2 1/11/2014 15:23 Z-Wave New Interface: Controller Manufacturer: PowerLynx, ID=0x1, Type=0x4 1/11/2014 15:23 Z-Wave New Interface: ...................................................................... 1/11/2014 15:23 Z-Wave New Interface: .............................. FINISHED .............................. 1/11/2014 15:23 Z-Wave New Interface: ...................................................................... 1/11/2014 15:23 Z-Wave New Interface is the SIS for the network. 1/11/2014 15:23 Z-Wave New Interface There is a SUC/SIS in the network. 1/11/2014 15:23 Z-Wave New Interface Controller is static lib. 1/11/2014 15:23 Z-Wave New Interface Controller chip type is ZW050x. 1/11/2014 15:23 Z-Wave The interface's security support has been set. 1/11/2014 15:23 Z-Wave New Interface: Z-Wave PC Controller is Type: Static Controller 1/11/2014 15:23 Z-Wave New Interface: Z-Wave PC Controller Library Version: Z-Wave 3.99 (ZDK 6.51.3) 1/11/2014 15:24 Z-Wave Starting Z-Wave Polling for Network D1FE165A... 1/11/2014 15:27 Z-Wave Z-Wave Interface New Interface (1) has been reset to its defaults. 1/11/2014 15:27 Z-Wave Warning New Interface: Erasing the interface... 1/11/2014 15:27 Z-Wave New Interface: Restoring node information from the file C:\Program Files\HomeSeer HS3\Data\Z-Wave\ZNet_Home_0161D2CC.ZWave. Please wait... 1/11/2014 15:27 Z-Wave New Interface: Erase complete - sending the network ID to the interface. 1/11/2014 15:27 Z-Wave New Interface: Controller firmware version: 5.2 1/11/2014 15:27 Z-Wave New Interface: Controller Manufacturer: PowerLynx, ID=0x1, Type=0x4 1/11/2014 15:27 Z-Wave Warning A Z-Wave interface on the system is being restarted - some Z-Wave signals could be missed. 1/11/2014 15:27 Z-Wave Starting Z-Wave Polling for Network C140F4FF... 1/11/2014 15:27 Z-Wave New Interface: Getting node information from controller... 1/11/2014 15:27 Z-Wave New Interface: Z-Wave Ethernet at IP 192.168.0.29, connected to interface ok. 1/11/2014 15:27 Z-Wave Error New Interface: Exception transmitting to IP 192.168.0.29: Unable to write data to the transport connection: An established connection was aborted by the software in your host machine. 1/11/2014 15:27 Z-Wave New Interface: Getting node information from controller... 1/11/2014 15:27 Z-Wave Error New Interface: The New Interface interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2). 1/11/2014 15:28 Z-Wave Warning Trying to re-connect to Ethernet interface at IP 192.168.0.29... 1/11/2014 15:28 Z-Wave Error New Interface: The New Interface interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2). 1/11/2014 15:28 Z-Wave New Interface: Restoring node information for node 1... 1/11/2014 15:28 Z-Wave New Interface: Z-Wave Ethernet at IP 192.168.0.29, connected to interface ok. 1/11/2014 15:28 Z-Wave New Interface: Restoring node information for node 4... 1/11/2014 15:28 Z-Wave New Interface: Restoring node information for node 3... 1/11/2014 15:28 Z-Wave Warning Trying to re-connect to Ethernet interface at IP 192.168.0.29... 1/11/2014 15:28 Z-Wave Warning In Z-Wave init(A), no response getting initialization information. 1/11/2014 15:28 Z-Wave New Interface: Getting node information from controller... 1/11/2014 15:28 Z-Wave New Interface: Restoring node information for node 8... 1/11/2014 15:28 Z-Wave New Interface: Restoring node information for node 7... 1/11/2014 15:28 Z-Wave New Interface has successfully been made the SIS for this network. 1/11/2014 15:28 Z-Wave New Interface: Restoring node information for node 6... 1/11/2014 15:28 Z-Wave New Interface attempting to set as SUC/SIS... 1/11/2014 15:28 Z-Wave New Interface is the Primary Controller for this network. 1/11/2014 15:28 Z-Wave New Interface Controller is static lib. 1/11/2014 15:28 Z-Wave New Interface Controller chip type is ZW050x. 1/11/2014 15:28 Z-Wave The interface's security support has been set. 1/11/2014 15:28 Z-Wave New Interface: Z-Wave PC Controller is Type: Static Controller 1/11/2014 15:28 Z-Wave New Interface: Z-Wave PC Controller Library Version: Z-Wave 3.99 (ZDK 6.51.3) 1/11/2014 15:28 Z-Wave New Interface: Found 4 Z-Wave nodes in interface node ID 1 (New Interface) 1/11/2014 15:28 Z-Wave New Interface: Z-Wave interface node ID: 1, Home ID: C140F4FF 1/11/2014 15:28 Z-Wave New Interface: Z-Wave Serial API version: 5 1/11/2014 15:28 Z-Wave New Interface: Controller firmware version: 5.2 1/11/2014 15:28 Z-Wave New Interface: Controller Manufacturer: PowerLynx, ID=0x1, Type=0x4 1/11/2014 15:28 Z-Wave New Interface: Restoring node information for node 5... 1/11/2014 15:28 Z-Wave New Interface: Getting node information from controller... 1/11/2014 15:28 Z-Wave New Interface: Z-Wave Ethernet at IP 192.168.0.29, connected to interface ok. 1/11/2014 15:28 Z-Wave New Interface: Restoring node information for node 15... 1/11/2014 15:28 Z-Wave New Interface: Restoring node information for node 14... 1/11/2014 15:28 Z-Wave New Interface: Restoring node information for node 13... 1/11/2014 15:28 Z-Wave New Interface: Restoring node information for node 10... 1/11/2014 15:28 Z-Wave New Interface: Restoring node information for node 9... 1/11/2014 15:28 Z-Wave Warning A Z-Wave interface on the system is being restarted - some Z-Wave signals could be missed. 1/11/2014 15:28 Z-Wave New Interface: Node information has been successfully loaded - restarting the controller... 1/11/2014 15:28 Z-Wave New Interface: Getting node information from controller... 1/11/2014 15:28 Z-Wave New Interface: Z-Wave Ethernet at IP 192.168.0.29, connected to interface ok. 1/11/2014 15:28 Z-Wave Error New Interface: Exception transmitting to IP 192.168.0.29: Unable to write data to the transport connection: An established connection was aborted by the software in your host machine. 1/11/2014 15:28 Z-Wave New Interface: Restore of node information COMPLETE. 1/11/2014 15:28 Z-Wave New Interface: Getting node information from controller... 1/11/2014 15:28 Z-Wave New Interface: Z-Wave Ethernet at IP 192.168.0.29, connected to interface ok. 1/11/2014 15:28 Z-Wave New Interface: ---------------------------------------------------------------------- 1/11/2014 15:28 Z-Wave Initializing Z-Wave interface New Interface (HomeSeer Z-NET Ethernet) at 192.168.0.29, port 2001 1/11/2014 15:28 Z-Wave New Interface: ---------------------------------------------------------------------- 1/11/2014 15:28 Z-Wave New Interface: ====================================================================== 1/11/2014 15:28 Z-Wave New Interface: Exiting Ethernet Communications Thread 1/11/2014 15:28 Z-Wave New Interface is a SUC or SIS for this network. 1/11/2014 15:28 Z-Wave New Interface Controller is static lib. 1/11/2014 15:28 Z-Wave New Interface Controller chip type is ZW050x. 1/11/2014 15:28 Z-Wave The interface's security support has been set. 1/11/2014 15:28 Z-Wave New Interface: Z-Wave PC Controller is Type: Static Controller 1/11/2014 15:28 Z-Wave New Interface: Z-Wave PC Controller Library Version: Z-Wave 3.99 (ZDK 6.51.3) 1/11/2014 15:28 Z-Wave New Interface: Found 13 Z-Wave nodes in interface node ID 1 (New Interface) 1/11/2014 15:28 Z-Wave New Interface: Z-Wave interface node ID: 1, Home ID: C140F4FF 1/11/2014 15:28 Z-Wave New Interface: Z-Wave Serial API version: 5 1/11/2014 15:28 Z-Wave New Interface: Controller firmware version: 5.2 1/11/2014 15:28 Z-Wave New Interface: Controller Manufacturer: PowerLynx, ID=0x1, Type=0x4 1/11/2014 15:28 Z-Wave Error New Interface: The New Interface interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2). 1/11/2014 15:28 Z-Wave Warning Trying to re-connect to Ethernet interface at IP 192.168.0.29... 1/11/2014 15:28 Z-Wave New Interface: Getting node information from controller... 1/11/2014 15:28 Z-Wave New Interface: Z-Wave Ethernet at IP 192.168.0.29, connected to interface ok. 1/11/2014 15:28 Z-Wave New Interface is the SIS for the network. 1/11/2014 15:28 Z-Wave New Interface There is a SUC/SIS in the network. 1/11/2014 15:28 Z-Wave New Interface Controller is static lib. 1/11/2014 15:28 Z-Wave New Interface Controller chip type is ZW050x. 1/11/2014 15:28 Z-Wave The interface's security support has been set. 1/11/2014 15:28 Z-Wave New Interface: Z-Wave PC Controller is Type: Static Controller 1/11/2014 15:28 Z-Wave New Interface: Z-Wave PC Controller Library Version: Z-Wave 3.99 (ZDK 6.51.3) 1/11/2014 15:28 Z-Wave New Interface: Found 13 Z-Wave nodes in interface node ID 1 (New Interface) 1/11/2014 15:28 Z-Wave New Interface: Z-Wave interface node ID: 1, Home ID: C140F4FF 1/11/2014 15:28 Z-Wave New Interface: Z-Wave Serial API version: 5 1/11/2014 15:28 Z-Wave New Interface: Controller firmware version: 5.2 1/11/2014 15:28 Z-Wave New Interface: Controller Manufacturer: PowerLynx, ID=0x1, Type=0x4
Thank you.
