Look in the beta section
BLLock Upcoming Changes
Disable/Enable Users?
Blade, are you able to enable/disable user codes through the API now? If so I'd love to see some event actions for this. Also, what does ticking "Disable" on the user config do? I figured this would disable the user code in the locks, but it appears not to do anything that I can tell. Maybe that's a bug?
Originally posted by teladog01 View PostBlade, are you able to enable/disable user codes through the API now? If so I'd love to see some event actions for this. Also, what does ticking "Disable" on the user config do? I figured this would disable the user code in the locks, but it appears not to do anything that I can tell. Maybe that's a bug?
Originally posted by hjk View Post+1! I was thinking the same thing after reading the previous post, but cheeryfool beat me to it!
Sent from my iPad using TapatalkMy home is smarter than your honor roll student.
Once all users are added the new way into the lock, the users page for the lock is read from HS3 so it gets the list of users in the lock itself
If you delete the user from the lock the list will not return that user
That might be hard to do
Deleting a user is not an issue but the disabling part might not be doable
Hi Blade -
I'm working with another lock trying to convert it to the new plugin updates. I've got BLLock 3.0.11.0, ZWave 3.0.1.200 and HS3 Standard Edition 3.0.0.368 (Linux).
I run the Conversion but it doesn't clear out the ini file which tells me it hasn't completed successfully.
I've attached a detailed log. It looks like it's getting a 401 error when it's trying to read/write the pin slot. Please let me know if there is anything that I can do on this end.
PatAttached Files
Originally posted by Blade View PostOnce all users are added the new way into the lock, the users page for the lock is read from HS3 so it gets the list of users in the lock itself
I guess I was thinking of keeping a BLLock version of the users and comparing with the actual Lock/HS3 users. Disabled users would be unique to the PI, until they are re-enabled, at which point they would become lock users again.cheeryfool
Originally posted by Blade View PostIf you are talking about the actual ZWave device then no I do not update those at all. I let the zwave plugin update those
Looking at the plugin page I see the name, the lock shows only the user.
I'm trying to send a pushover message with the reference ID, ie: $$DSR:365: that is the ref ID of the Zwave (lock) device. Does the plugin status have a ref ID or can a virtual device be created to refer to it?
Jim
