Is there a way to disable and enable the harmony hub plugin via an event? If so, this would allow users to remotely shut down and restart plugin to get it working again once there is a failure to connect. This is the only way around the consistent disconnecting and failure to connect again issues? Any thoughts on this are much appreciated....Rick
Disabling and Reenabling Harmony Plugin with Event?
I think there is a plugin created by Jon00 that might let you do this.
(found it here: https://forums.homeseer.com/showthread.php?t=150325)
