Originally posted by Pete
View Post
Discussions related to HS3 Beta build 3.0.0.449
All I can say is try the installation of Windows 10 Pro Redstone version using only Cortana. Ask her anything while installing....- Pete
I would let it run and see if memory eventually comes down. .NET can act strange and not clean up memory as expected.
Originally posted by Moskus View PostScripting support on Linux is still too weak for that.
No, my conclusion is that it's either HomeSeer or Windows 10 1803 who is acting up.
It could be either. Or both.
Originally posted by rjh View PostI would let it run and see if memory eventually comes down. .NET can act strange and not clean up memory as expected.
In every case, roughly after 40-48 hours after a reboot, HomeSeer would run out of memory (according to the error messages in the log) and begin to malfunction.
The ONLY change was the update from Windows version 1709 to 1803.HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
I know you won't believe me, but I bet Windows is in a bad state, some system files or registry entries are changed. I would love to see you simply move your HS folder to another system and see if it acts the same. Do you have another PC, or laptop that you could test it on?
Did you let 1803 finish patching itself? It seems to take a while after the initial install to reach update stability.
Sent from my iPhone using Tapatalk_______________________________________________
Originally posted by rjh View PostI know you won't believe me, but I bet Windows is in a bad state, some system files or registry entries are changed. I would love to see you simply move your HS folder to another system and see if it acts the same. Do you have another PC, or laptop that you could test it on?
This mirrors my experience with 1803. Having talked to several computer repair folks about my issues with 1803, they had a lot of computers in for repair that were in bad shape. Each had their own 1803 war stories to share, with their own take (and little consensus) on the real problem.
My opinion is that a fresh install of W10 is the only way out of the mess. At least, it was the only thing that worked for me..... YMMV.HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
Home Assistant 2024.3
Enabled Plug-Ins
Originally posted by jlrichar View PostDid you let 1803 finish patching itself? It seems to take a while after the initial install to reach update stability.
This is an extremely interesting notion and a behavior with which I am not familiar. It might, however, explain the behavior of my computer. 1803 would update "successfully" and run normally for a few hours and then, attended or not, it would crash with a black screen and spinning cursor. It was a repeatable condition, which could not be solved by a repair or rollback, only by a fresh install.....HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
Enabled Plug-Ins
Folks, the choice is stark but a reality. An allegiance to Windows or a working HS3. It's been stated time and time again here. Windows is heading to the cloud.
Using two different variants of Linux on two different boards and no real problems for months.
If your favourite plugin cannot adapt to the world of Linux maybe it's time you found an alternative.
- Likes 1
In relation to this thread, is there a complete changelog available of each release?
I am now on release 425 but in release 435 an bug with the event system should have been solved. However the current release is 445 and the changelog isn't mention anything about previous updates and their changes.- Bram
Send from my Commodore VIC-20
Ashai_Rey____________________________________________________________ ________________
HS3 Pro 3.0.0.534
PIugins: ZMC audio | ZMC VR | ZMC IR | ZMC NDS | RFXcom | AZ scripts | Jon00 Scripts | BLBackup | FritzBox | Z-Wave | mcsMQTT | AK Ikea
I have tried HS3 on two machines running 1803.
The first is my HS3-server that's been updated from two or three times. The last one from 1706 to 1803. That's when the problems started.
Figuring it could be that the update procedure was causing problems, I grabbed the ISO-files (using MediaCreationTool.exe from Microsoft) and set it up again. Directly to 1803. Exactly the same problems!
I didn't find any way to install the 1706 version of Windows 10 again, so I installed Windows 7. No problems. Just like Windows 10 before the 1803 update.
All three "computers" are virtual running on exactly the same hardware with exactly the same software installed. The VMs are configured with precisely the same settings. And of course exactly the same copy of the HS3 folder on all.
Originally posted by jlrichar View PostDid you let 1803 finish patching itself? It seems to take a while after the initial install to reach update stability.HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Originally posted by tenholde View PostPeople on these boards have trouble with both windows and Linux, while most have working reliable systems on either. Your posting portrays to be fact what is only your opinion.
Even MS in their wisdom have ploughed finance and resources into the efforts of Linux in the shape of Xamarin's development of the Mono Project and it's ability to run .Net Framework designed programs in the Linux environment. Businesses like Homeseer have benefited greatly from this and they got my business purely on this basis.
Closed source technologies are no longer acceptable in this day and age. As Moskus has experienced, you're only one update away from a broken system as he struggles to downgrade his Windows system to get it HS3 working with it. This scenario would hardly fill a Windows user with much confidence.
Originally posted by concordseer View PostAs Moskus has experienced, you're only one update away from a broken system as he struggles to downgrade his Windows system to get it HS3 working with it.
I have other services running on Linux, and they aren't without problems either. I've been running HomeSeer on Windows for over 10 years. Just because update 1803 is acting up, I see no reason to stop now when it is my OS of preference.
If it's Windows that is the problem, it's not very likely that I'm the only one having issues. So it will be fixed. I will report it too.
If it's HS3 causing problems, then I might be the first to have this problem but others will follow. HST can't just abandon Windows if they want to stay in the game, so they need to fix it when they can replicate the problem.
My point is: As long as you are running software on a OS you might get problems. Now it was my turn. I'm just trying to help out others (or HST) if they see the same thing.HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Originally posted by Moskus View PostYeah. But the same can also happen with Linux, so it really doesn't matter.
All tested and found to be working fine. Raspbian Stretch and Mono 5.12
In light of the fact that many Windows users have not loaded .445 you may have difficulty apportioning the fault to either Windows or HS3 but hopefully you do isolate the problem. It does seem odd that everything was working fine prior to the latest Windows update.
Unfortunately the "if it ain't broke don't fix it" rule does not apply in your case as the Windows update was forced upon you.
