My system has taken a huge nosedive. I had just fixed some of the problems from my previous post (OK, some of them just went away), then last night my wife rearranged the office in which the HomeSeer server sits. She shut down the computer and unplugged all the externals. That's when things really went south.
For starters, HomeSeer is not communicating with the Insteon devices. No events are having the desired effect.
The startup log alternatively shows an error on startup:
3/27/2018 11:00:57 AM ~!~Warning~!~Error starting web server, port in use? Are you running a web server on the designated port? Edit settings.ini in the Config folder and change gWebSvrPort=## to a different port #. The requested address is not valid in its context
...and the next time I boot, will show NO error. However, I cannot control anything from the web interface.
Insteon Configuration showed an error saying it basically can't find the interface. The COM port field was blank. I typed COM4 into it and saved, then I went to Plug-In Manager to cycle the Insteon module. I turned it off...and it disappeared from the list of plug-ins. It's also gone from the drop-down menu.
The log at this point shows:
Mar-27 11:09:20 AM Info Plugin Insteon with instance: has disconnected
Mar-27 11:09:24 AM Updater An item in the Updater is temporarily unavailable: Unable to connect to the remote server Item: http://homeseer.du-pre.com/HS3/Limit...D3/updater.txt
Mar-27 11:09:30 AM Updater An item in the Updater is temporarily unavailable: Unable to connect to the remote server Item: http://homeseer.du-pre.com/HS3/HarmonyHub3/updater.txt
Mar-27 11:09:37 AM Updater An item in the Updater is temporarily unavailable: Unable to connect to the remote server Item: http://homeseer.du-pre.com/HS3/Plugwise3/updater.txt
Mar-27 11:09:39 AM Updater An item in the Updater is temporarily unavailable: Unable to connect to the remote server Item: http://homeseer.du-pre.com/HS3/PlugwisePro3/updater.txt
Mar-27 11:09:42 AM Updater An item in the Updater is temporarily unavailable: Unable to connect to the remote server Item: http://homeseer.du-pre.com/HS3/Think...r3/updater.txt
Mar-27 11:09:44 AM Updater An item in the Updater is temporarily unavailable: Unable to connect to the remote server Item: http://homeseer.du-pre.com/HS3/Caddx3/updater.txt
Mar-27 11:09:49 AM Updater An item in the Updater is temporarily unavailable: Unable to connect to the remote server Item: http://homeseer.du-pre.com/HS3/FritzBox3/updater.txt
Mar-27 11:09:53 AM Updater An item in the Updater is temporarily unavailable: Unable to connect to the remote server Item: http://homeseer.du-pre.com/HS3/IPThe...t3/updater.txt
Bottom line, the system has gone completely insane....and I am following close behind. Please tell me there is one simple thing that can explain all of this.
