I have an ECM-1240 recently started having some issues with the UltraECM plugin.
At some point, I realized ECM-1240 data was no longer being updated. I am not entirely sure what change triggered this - it has been a while. After trying several things (updating HS3, updating the plugin, re-installing the plugin, etc.), I am still unable to get any data to show up.
I can confirm that the device is present and functional on COM6. I am able to connect via the Interface Application without issue.
I do notice that I am unable to get the 19200 baud rate to "stick" on the configuration page. No matter how many times I tell it to go to 19200, it will always revert to 115200 when I return to the Options tab.
It does not appear that I can command the ECM-1240 to operate at 115200 - I thought that might be worth a try.
That said, based upon the configuration file, it appears to be only a GUI fluke:
From the logs, I see this shortly after enabling the plugin (reading bottom to top):
Then, I start to see periodic messages that indicate a watchdog timeout:
Not sure where to go from here. Let me know if you need more information or if there is anything I can try...?
[Settings] Version=3.0.6300.28069 [Options] PacketBuffer=1 PostDataType=0 PostDataInterval=30 PostDataURL=http://api.smartenergygroups.com/sites/ UnitType=0 TempDegreeUnit=True TempDegreeIcon=True GEMBaudRate=19200 ECMBaudRate=19200 LogLevel=7 [Rate] DefaultCost=0.12 [WEBUsers] AuthorizedRoles=15
Apr-19 9:45:30 PM Informational Brultech ECM Device connection established to COM:6. Apr-19 9:45:30 PM Plug-In Finished initializing plug-in UltraECM3 Apr-19 9:45:29 PM Info Plugin UltraECM3 has connected. IP:127.0.0.1:54891
Apr-19 9:58:36 PM Warning Watchdog Timer indicates No response response from the Brultech device 'COM:6' for 786 seconds.. Attempting to reconnect ...
