Does the test button next to the handler fire the command stack on that handler, ignoring the actual Event criteria requirements itself? I checked the docs and it wasn't explained.
Clarify: Handler TEST Button
Originally posted by Blade View PostThe test should fire the handler to test out the commands
Let me know if you do not see this happen
I tried several different trigger types just to double check, with one being:
HS[ControlDevice~Ceiling Lights (Z)~Off]
No dice on any of them.
Originally posted by fksk View PostBob, unfortunately it is not firing the event that I am calling via RunEvent per the BLGData plug documentation.
Originally posted by Blade View PostThe test button should fire the commands associated with the handler
It will not take into account any offsets defined in the handler
I also tried several different trigger types (events, device commands, etc) just to double check, with one being (as a pure example):
HS[ControlDevice~Main Ceiling Lights~Off]
Originally posted by Blade View PostI will need a debug log of this
1. Turn on debug logging in the plugin
2. Run the test for the handler
3. Turn off debug logging
Attach the BLGData-Detailed.log zipped so I can see it
It is in the HS3 root folder
Maybe also a screenshot of the handler
Done. I'm gonna IM you the Dropbox link to the log file.
