Access to COM3 Denied!
    Trying to use Z-Flash for the first time. When I try to enable COM3, which is the only COM port that appears in the drop-down, I get a message telling me that access is denied. Any help would be much appreciated. Thanks!
    You should run Z-Flash on a separate computer with a separate Z-Wave stick. That said if you running HS3 on the computer you should shut it down before using Z-Flash.
      Thank you!
