Version 3.0.1.0 was submitted to the updater this morning. It might be a little while before it shows up in the updater.
Changes in this version:
**Note - this is a major release. You will need to remove your existing HAI devices and any Events that use your existing devices. I apologize but, this is a beta release. If this version tests out ok, it will be moved to a General Release and become a paid plugin at that point. Any changes to the General Release version will not require you to remove devices.
***Backup your current installation so you can revert back if needed!!
Steps to install:
The changes in this version now allow you to create HS3 events for Alarm trip functions. So, in addition to writing events to arm/disarm your panel, you can now be notified or act on area alarms such as burglary, fire, water, etc.
Please test this out thoroughly. I have been running it for about a week now and have not noticed any issues. If you do run into anything, post it in this thread and email me your logs (robmasonjr67 at yahoo dot com)
- Version change - major release.
- Added support for all HAI panel types.
- Changed MySQL datatype of id from SMALLINT UNSIGNED to INT UNSIGNED.
- Devices are now created with eControlUse=True to allow support for IFTTT.
- Refactoring older code.
- Areas can now be selected to be included as HS devices.
- Areas now support triggers for: Burglary, Fire, Gas, Aux, Freeze, Water, Duress, Temperature.
- Added more status graphics for Areas.
- Registers for unsolicited packets *after* plugin is initialized.
- Plugin web page now defaults to the help tab.
Steps to install:
- Stop your current HAI plugin from running.
- Remove all HAI devices and events.
- Install this version from the updater.
- Enable the plugin.
- From the HAI plugin page, click on the Areas tab and enable specific area alarms you want to track.
- Do the same for Outputs (optional).
