HS3: I was trying to do a special trigger for Transmit On. I select that from the list of special triggers. It then displays a drop-down to select the device, but the drop-down is empty. Have you seen this before and know what may cause that?
Insteon Special Triggers Device Drop-down is empty
Tom,
have you tried with a new event, or are you editing an existing event? sometimes the hs3 UI gets stuck.Mark
HS3 Pro 4.2.19.5
I was editing an existing event that had previously been set to manually triggered. I just tried creating a new event and have the same behavior. I closed down all browser windows and tried again with the same results. The normal full HS device list populates for other conditions and actions.
I thought that I give an action a try. I tried beep device and it also has an empty drop down.
I just shut down HS3 and restarted and now it works.
