Originally posted by The Profit
View Post
Aeotec ZW097 Dry Contact Sensor Questions
HomeSeer Version: HS3 Standard Edition 3.0.0.548
Originally posted by Timon View PostThat's just one reason I don't use them anymore. The DWZWAVE2.5-ECO has both external contact and internal magnetic style in the same package. It's also Z-Wave Plus. Haven't used one my self but I'm sure other here have. It also has tamper which the Aeotec doesn't. They are also less expensive.
Thanks Timon, If I had seen these online I would have never seen that these were both a dry contact and door sensor!
HS3 3.0.0.423 & HSTouch 3.0.55 with 700 Devices, 358 Events
Plugin's:
BLBackup, BLOccupied, BLShutdown, EasyTrigger, Ecobee,
weatherXML, Jon00 Alexa Helper, Network Monitor, Z-Wave 3.0.1.206HS4 4.2.6.0 &HSTouch Designer 3.0.80
Plugin's:
BLBackup, BLOccupied, BLShutdown, EasyTrigger, Ecobee, Nest, AK Bond
weatherXML, Jon00 Alexa Helper, Network Monitor, MyQ, Z-Wave
Originally posted by The Profit View PostThanks Timon, If I had seen these online I would have never seen that these were both a dry contact and door sensor!
BTW, I think the unbranded one on Monoprice is the same, haven't checked with them, and it's a few $'s cheeper. Still I don't know that I'd get it unless I needed a lot of them which made the lower cost worthwhile.HomeSeer Version: HS3 Standard Edition 3.0.0.548
I also use that sensor as a dry contact for my washer monitor (using a photo-transistor over the 'finished' light). It works great.--------------------------------------------------
**** Do You "Cocoon"? ****
Originally posted by BraveSirRobbin View PostI also use that sensor as a dry contact for my washer monitor (using a photo-transistor over the 'finished' light). It works great.
Wow, nice method! There are many ways to do this. Not to drive this into 'off topic' territory, but the problem i had was actually 'mounting' the phototransistor to the washer light (tape method, not a 'pretty' solution, but it does work and it doesn't tamper with any of the washer components (same with your solution).--------------------------------------------------
