Discussions related to HS3 build 3.0.0.357
    This thread is for discussing build 3.0.0.357 of HS3.
    Did anything change from .356?
      @Rich
      Is this the release version?
        Originally posted by Pete View Post
        @Rich
        It is for Windows. Not sure about Linux.
          Thanks Randy. Just started to watch V256 on Linux on one of two boxes.
            HSTouch was fixed so it now restarts properly from setup and a lockup with clients was fixed. Also, some fixes where added related to multi instance plugins.
            Build 357 is released for all systems.
              Thank you Rich...
              Updated HS3 Pro Buntu machine from V. 356 to V. 357.
              Updated HS3 Pro running in Buntu 64 (vintage 16.04). Just this on startup long..
              Sep-07 6:59:16 PM Startup ************************************************************ ********************
              Sep-07 6:59:16 PM Startup HomeSeer version 3.0.0.357 Edition: HS3 Pro Starting Now
              Sep-07 6:59:51 PM Info ASCII listener started on port 11000
              Never seen the following type of message in start up log. Only saw it on startup here.
              Sep-07 6:59:53 PM Warning Not running script since its already running:/HomeSeer/scripts/Jon00RSSHS3.vben Single instance option enabled in event properties
              Updated Homeseer Lite (Zee) to 3.0.0.357 on Friday, September 8, 2017 in the AM.
              Sep-08 8:33:24 AM Startup HomeSeer version 3.0.0.357 Edition: HS3 ZEE S2 Starting Now
              No issues on boot log.
              Switching Homeseer Lite here between using an ARM or AMD CPU created two files here for check password. One for ARM and one for .386 CPUs.
              Thinking too I changed the go script as I run Homeseer in the root on two computers IE: /HomeSeer.
              Some Linux users run HomeSeer in the /home/HomeSeer or /opt/HomeSeer directory.
                Multiple dos windows
                Why, when I start HS3 .357, do I get multiple DOS windows?
                Win7 Ultimate
                Michael
                  Win7 Ultimate
                  Under the plugins page you probably have developer mode checked. It does this. Just uncheck and restart.
                    Thank you. That was it.
                    Michael
                      .357 running on Raspberry Pi 3 overnight. No problems to report. All working fine so far.
                        So... just went to the downloads page and still see .318.
                        Is this still beta? I thought it was released.
                        Robert
                          I found it under Tools/Setup. Press Check Now under Updates.
                            Thanks...and while I have it checked, I never see any messages from HS unless I start it outside of Fire Daemon... Usually, I download from the site and apply manually.
                            Robert
                              Weirdly, I don't see any such option.
                              I don't even see an Updates section!
                              I see "Other Settings" and Check for HS3 update at startup.
                              So I shut it down and started it up and it installed the update.
                              Would still love to know why my Tools/Setup is different from yours!
