Old October 29th, 2017, 05:08 AM
smargi smargi is offline
Seer
Aeotec ZW062-C Gen5 Garage Door Controller compatibility - works with HS3
Hi.
Does anyone Know or try connecting the Aeotec ZW062-C Gen5 Garage Door Controller to HS3 system and if it fully compatible...?
Old October 29th, 2017, 10:54 AM
macromark's Avatar
macromark macromark is offline
HomeSeer Technologies
Quote:
Originally Posted by smargi View Post
Hi.
We tested it when it came out. No issues.
Old October 30th, 2017, 03:54 AM
Seer
Hi..
Great thanks,
Old October 30th, 2017, 11:04 AM
balpaugh balpaugh is offline
Seer
Question Battery Charge Detection
I have one that works however the battery detection does not, it always show discharged. I believe it was a known issue, has this issue been resolved?
Bryan
Old December 30th, 2017, 02:55 AM
shai shai is offline
Seer
Quote:
Bryan
Hi i thought I'd ask the same question. How do you get the battery status of the tilt sensor?
I also found from the engineering papers that there is a parameter to read the temperature. How do we access this data from the device?
Old January 17th, 2018, 04:37 AM
Seer
update anyone?
guys anyone managed to get temperature and tilt sensor battery status reading from the device?
Old January 17th, 2018, 10:01 AM
Richel Richel is online now
Seer Master
Quote:
Why is this not sold in the US?
Elliott
Old January 23rd, 2018, 09:28 PM
julez julez is offline
Seer
I bought a pair online and they work great. However the tilt sensor constantly fails to show the correct info. 90% of the time they show as stopped.
I've tried to re-pair them and to calibrate them. I'm not sure what the issue is. I might try new batteries in both just to see if they were shipped with bad batteries.
One thing I need to talk to support about is whether they have to use the wire clips attached to the switch or if I can do what I'm doing and directly attack them to the terminal on the motor housing.
HTML code is Off
GoControl Garage Door Controller cpearson88 HomeSeer General Discussion Area 0 July 10th, 2017 01:21 PM
Chamberlain MyQ Garage door controller PLUGIN VikingCoder HS3 / HS3PRO Discussion 114 May 1st, 2017 08:55 AM
Z Wave Garage door controller ? TxStig Lighting & Primary Technology Discussion 2 November 18th, 2016 09:05 PM
Aeotec Z-Wave Garage Door Controller The Profit HomeSeer Z-Wave Plug-in 0 June 22nd, 2016 02:01 PM
