Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion
Lighting & Primary Technology Discussion Lighting & Primary Technology General Discussion
Old August 2nd, 2011, 08:57 AM
wpiman's Avatar
wpiman wpiman is offline
Aeon power meters.....
Is is reporting my washer is pulling 33685.504 watts..... rollover software bug?
HS3 Pro Edition 3.0.0.368 (Windows Server 8 on ESXi box)
2 Znets- Ecobee
Old August 2nd, 2011, 09:54 AM
rmasonjr's Avatar
rmasonjr rmasonjr is online now
Are you talking about the Smart Energy Switch?
Old August 2nd, 2011, 01:31 PM
wpiman's Avatar
Yes...
Yes- sorry for the vagueness. That is the one.
My washing machine is on there-- and not running. My log shows.....
8/2/2011 12:48:39 PM Device Update Device: Basement Washing Machine Electric Meter kW Hours value set to 7400 (74 kW Hours)
8/2/2011 12:50:19 PM Device Update Device: Basement Washing Machine Power value set to 268435.456 (26843546/W)
8/2/2011 12:50:29 PM Device Update Device: Basement Washing Machine Power value set to 0 (0/W)
I am pretty sure my washing machine is not using 27 megawatts of trickle change. My TED doesn't indiciate that to be the case-- although, it doesn't go that high. :-)
Old August 2nd, 2011, 01:46 PM
rmasonjr's Avatar
Yikes - that is very strange. I have 2 of these installed on TVs (and 2 more on the way). I havent seen any tall spikes like that. I might try one out on my washer and let you know what it says.
Old August 2nd, 2011, 02:25 PM
wpiman's Avatar
My washer is not even on at this time. That is the scary part... It is a mechanical start mechanism-- I imagine the load is always zero.
Old August 5th, 2011, 09:43 AM
rmasonjr's Avatar
I finally hooked one up to my washer and here's what I have in my logs:
Old November 28th, 2016, 08:11 PM
Steve Q's Avatar
Steve Q Steve Q is offline
I am using several Aeon AEDSB09104ZWUS Smart Energy Monitors. They work great! One of the best Z-wave buys out there; $20 EACH!
Below is a graph of my Values for my main power feeds (A+B) compared with my daily power usage provided by my power company. I have a smart power meter and I can get the results from the power company's web site. As you can see, the agreement is excellent!!! However the values from the Aeon monitor are 55% lower than the power company.
I have explored this issue many times and I have not uncovered any possible explanation. Does anyone have any ideas/experience in this area?
Steve Q
Old March 15th, 2017, 04:37 PM
Mahera Mahera is offline
Hello.
I know that's an older topic.
I believe the first gen Aeon power meters only "guesses"
The wattage.
For power you neeed volts and amps
So if your voltage is different from what the meter expects then your calculation will be off.
The second generation I believe is hooked up to the ciruit and "knows" the voltage and therefore the calculated wattage is way more precise.
I don't have first generation device hooked up, is there a setting somewhere for the voltage?
Best would be to actually measure the voltage on the circuit breakers. Keep in mind that the voltage will change depending on your feed and load at any given time.
Old March 15th, 2017, 05:02 PM
Steve Q's Avatar
My current sensors are attached to the main power feeds from the power company. Nominal voltage is 115-120VAC. It does not change much.
I suspect these version 1 devices are simply calibrated wrong. There is no way that I know to recalibrate them. Maybe they are intended to be used in Europe on 220V wiring?
This is not a big issue for me. I can simply apply a correction factor if I need an accurate measurement. But I am mostly looking at trends and changes during the day.
Steve Q
