Aeon Multisensor - Gen 5 & Multisensor 6
    I am just getting started with HomeSeer - what I have seen so far leads me to believe its a really power and flexible system.
    I've purchased a number of Z-Wave nodes to get started -
    5 x Greenwave 1 Port Powernode
    2 x Aeon Multisensor Gen 5
    1 x Aeon Multisensor 6
    I've got the Greenwave Powernodes connected and running without issue, i've set 60 second polling to see the power usage - great :-)
    However, I'm having problems getting the Multisensors to report in a timely manner, namely providing movement alerts in real time and temperature/light/humidity every ten minutes...
    I've gone through the process of setting the parameters as mentioned on several sites -
    Parameter Value Size Function
    3 240 2 PIR Detection timeout
    4 1 1 Enable Motion Sensor
    101 128+64+32+1 (225) 4 Items to report - Lux, Humid, Temp, Batt
    111 600 4 Reporting interval - Seconds
    However, I also see in the HomeSeer log file that it appears to be setting these values to some other preset e.g. reporting interval, 60 minutes...?
    I am assuming that because HomeSeer is sending other values then this is resetting the node to something else and therefore it's not reporting as expected?
    I wondered if anyone could share their experience of using these devices with HomeSeer?
    Many thanks,
    Andrew
