Warning message in log files
    I'm getting the following logs every seconds:
    Jan-13 9:19:11 PM Warning If this system is not on a network, disable UPNP in Setup. If HS2 is also running, disable UPNP on that system.
    Jan-13 9:19:11 PM Warning UPNP Discovery is not running, most likely your PC does not have a valid IP address, will try to enable later: Invalid arguments
    Jan-13 9:18:41 PM Warning If this system is not on a network, disable UPNP in Setup. If HS2 is also running, disable UPNP on that system.
    Jan-13 9:18:41 PM Warning UPNP Discovery is not running, most likely your PC does not have a valid IP address, will try to enable later: Invalid arguments
    Jan-13 9:18:11 PM Warning If this system is not on a network, disable UPNP in Setup. If HS2 is also running, disable UPNP on that system.
    Jan-13 9:18:11 PM Warning UPNP Discovery is not running, most likely your PC does not have a valid IP address, will try to enable later: Invalid arguments
    Jan-13 9:17:41 PM Warning If this system is not on a network, disable UPNP in Setup. If HS2 is also running, disable UPNP on that system.
    Jan-13 9:17:41 PM Warning UPNP Discovery is not running, most likely your PC does not have a valid IP address, will try to enable later: Invalid arguments
    What does this mean?
    System Info:
    Current Date/Time: 1/13/2018 9:23:07 PM
    Linux version: Linux hometrollerSEL 3.16.0-031600-generic #201408031935 SMP Sun Aug 3 23:56:17 UTC 2014 i686 i686 i686 GNU/Linux System Uptime: 7 Days 3 Hours 46 Minutes 27 Seconds
    IP Address: 192.168.0.11
    Number of Devices: 236
    Number of Events: 45
    Available Threads: 190
    Enabled Plug-Ins
    2.0.26.0: BLRing
    2.0.0.1: EZFlora
    5.0.0.58: Global Cache Pro
    3.0.0.25: ImperiHome
    3.0.6.0: Insteon
    3.0.1.6: Kodi
    3.0.0.76: weatherXML
    3.0.1.179: Z-Wave
    Personally here have not seen that message. I have though never enabled or used UPNP with Homeseer.
    It could be that one of your plugins is wanting to use UPNP. Maybe Kodi? Just a guess? Have you recently enabled a new plugin?
      Is there anything else sharing the same port number as HS3. Try changing the HS3 port number and see if that helps.
        I did have the Media Controller plug-in install and running for a bit doing some testing, but was disabled. I removed the .ini file in the config folder and that seem to have fixed it.
