Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > CFGuy Plug-Ins/Scripts > HSTV
HSTV Discussions related to the HSTV TV listings script package.
Old July 22nd, 2003, 04:13 AM
tonlof's Avatar
tonlof tonlof is offline
What can be wrong?
Tony Lofgren | Kungsor | Sweden
Windows 2000 Server, MS SQL, P4 2,6GHz 512Mb ram, TEMP05 V5.00, DS9097, 1Wire Dallas weatherstation, HS PCI Modem, Basic Stamp for I/O
Old July 23rd, 2003, 02:10 PM
CFGuy's Avatar
CFGuy CFGuy is offline
Have A Blessed Day
Please send me your hstv.ini file and I'll try to figure out what is causing this error.
Jeff Farmer
HomeSeer user since March, 2000
Old July 23rd, 2003, 05:16 PM
CFGuy's Avatar
Have A Blessed Day
Tony,
From the ini file you sent, it is showing SQL Server as the database type. But in the error image above, it says Access Driver.
If you are running Access then go to the Admin page and select Access as the database type. If you are runing SQL Server, then delete the ODBC connection for Access and recreate one for SQL Server.
Jeff Farmer
Old July 24th, 2003, 07:22 AM
tonlof's Avatar
Thanks, I think odbc change back after upgrading hstv. But is back to sql server now, with a new error.
Old July 24th, 2003, 09:15 PM
CFGuy's Avatar
Have A Blessed Day
I found the error and will have a fix posted this weekend.
Jeff Farmer
Old July 25th, 2003, 03:37 AM
tonlof's Avatar
Old July 26th, 2003, 09:38 AM
CFGuy's Avatar
Have A Blessed Day
Tony,
Check your email. I sent you a fix for this error.
You can run the version I emailed you until HSTV version 2.1.3 is released. Then whenever you upgrade HSTV you will get the newest version of hstv.exe. It will also have the bug fix in it.
Jeff Farmer
Old July 27th, 2003, 09:55 AM
tonlof's Avatar
HTML code is On
