Go Back   HomeSeer Message Board > Media Plug-ins > Media Discussion > SqueezeBox Plug-In (3P)
SqueezeBox Plug-In (3P) Discussion area for the SqueezeBox plug-in by PCP.
Old May 2nd, 2017, 03:43 PM
skarragallagher skarragallagher is offline
Seer Master
Disable Inactive Players
I really need a way to disable stale inactive players. If we can't remove them then just disabling them so they don't appear in the drop down lists when configuring events. I have like 3 with same name.
Removing them from the INI manually will create many issues for me with the players that are numbered higher... For instance If I were to remove players 5-10 which are stale and no longer used, any player above this (11 and up) would then recreate starting at 5 and be recognized as a new player. All of the devices and events that were created will then have to be recreated which is an enormous amount of work given how extensive I use this plugin.
I have asked for something to remove stale players many other times and I really need a solution here.
I am begging now.
Old May 3rd, 2017, 06:52 AM
pcp pcp is offline
Super Seer
Hello, from your original request, I had this on the todo and did experiment some but was not satisfactory (of completly ignoring and removing them). Marking them as disabled so that they do not show up in event configuration for example should be easier. I will have to look into this alternate approach.
Old May 3rd, 2017, 02:08 PM
Seer Master
Quote:
It would be nice to be rid of them permanently but i will certainly settle for disable from views. Thanks for looking at this again.
Old May 18th, 2017, 07:13 PM
Seer Master
Just checking in to see if you made any headway
Old May 20th, 2017, 09:58 AM
pcp pcp is offline
Super Seer
Yes I have but not completed yet. Hope soon but kind of busy with lots going on these days.
Old May 21st, 2017, 08:59 AM
pcp pcp is offline
Super Seer
The updated version should be in the updater next week. There is a new checkbox per player in the plugin status web page to enable/disable players.
HTML code is On
Support for ~ (Inactive) Profile selection in HS3 dzee Blue Iris Plug-In 6 July 28th, 2016 09:36 AM
Computer active/inactive image sirmeili HS3 Graphics & Status Icons 2 July 8th, 2016 10:53 AM
Problem with RF becoming inactive Ronnie BLRF (3P) 11 September 19th, 2014 09:51 PM
UPB is showing Inactive Scrambled HomeSeer UPB Plug-In (Beta) 6 October 5th, 2006 12:00 PM
Inactive Zone? chrkov Elk M1 Plug-In 3 March 6th, 2006 07:56 PM
