How to send status in email
    Hi All
    Just installed this, but can;t figure out how to send an message when the status changes (got that bit done) wiht the current status (i.e. has it just switched to on battery or on AC)?
    I know I could have an event that runs every x-minutes to check status, but would prefer to use a more efficient device status change. just need to get the statu sin the e-mail
    Regards
    Mark
    ________________________
    Dell Zino HD - HSPRo 2.x
    HSTouch - iPhone 3GS, 4S, iPad2 and iPad 3, 3xKindle Fire (Wall mounted)
    2 x Brultech ECM1240 with UltraECM
    USB UIRT
    Cooper Aspire Z-Wave Switches
    WGL800 w ACRF2 and 3xDS10a (Sump Level/Activity sensing)
    HM ST812-2 Flood Sensor
    HSM100 - Motion Detector with Light and Temperature
    2GIG Thermostat
    BLDSC - Alarm Plug-in
    BLUPS
    UltraLog (SQL2008)
    Jon00 Plugins
    Host XR3 BT and Jon00 BT Proximity
    Global Cache IP2IR
    Foscam FI8918W
    I think you can set up an event to run when the value of "Power Status" changes from ON to OFF and vice versa. Then set the event to send an email to you.
      thanks bmora
      that worked
      USB UIRT
      2GIG Thermostat
      BLUPS
      UltraLog (SQL2008)
      Jon00 Plugins
      Global Cache IP2IR
      Foscam FI8918W
        FYI, you can also use the $$DS replacement variable to include a device's status in an email. So if you wanted the status of device A1 you would put $$DS:A1
          I like that feature, thanks for pointing it out.
