This plugin is designed to interface HomeSeer with your Ecobee Thermostats
Please report any bug.
Please read the User Guide before installing.
Changes to v3.0.0.29
- Fixed problem when changing settings due to side effect of the Schedules feature
Changes to v3.0.0.28
- Fixed problem with security protocol change on Ecobee servers
Changes to v3.0.0.27
- Added possibility to define schedules from config page, and apply them to a thermostat from an event action
Changes to v3.0.0.26
- Added "Set Hold Action Setting" action
- Added "Sensor In Use" device which report if the temperature sensor of the thermostat or the lilbee is currently in use
Changes to v3.0.0.25
- Fixed HVAC status when used with heat pump.
Changes to v3.0.0.24
- Fixed error description. Most of "The call failed for an unknown reason" errors should now have more descriptive messages.
Changes to v3.0.0.23
- Added "Humidifier Mode" and "Humidifier Level" devices.
Changes to v3.0.0.22
- refactor Ecobee.Net library to avoid installation problems on Linux (specifically on SEL)
Changes to v3.0.0.21
- Added ControlUse filed to devices, in order to be controllable from Google Home and Alexa
Changes to v3.0.0.20
- Added "Aux Heat" HVAC Mode
- Added new model names for Ecobee 4
Changes to v3.0.0.19
- Fixed error when Ecobee server returns an empty response.
Changes to v3.0.0.18
- Fixed bug when setting "Minimum Fan Runtime" to 0
Changes to v3.0.0.17
- Added "Minimum Fan Runtime" device
Changes to v3.0.0.16
- Fixed problem when resetting authorization
- Fixed problem with "Auto" icon on Linux
- In case of multiple thermostats, details for each thermostat are now requested in separate requests.
Changes to v3.0.0.15
- Fixed fan hold
Changes to v3.0.0.14
- Force refresh of authentication token when AuthenticationTokenExpired exception is received
- Added possibility to log to file
Changes to v3.0.0.13
- Added support for HS Replacement Variables in "Send Message"actions.
Changes to v3.0.0.12
- Fixed Current Program device status
Changes to v3.0.0.10
- Set root device to Offline when plugin can't reach server.
Changes to v3.0.0.9
- Added occupancy device for the main thermostat
- Added a temperature device for the main thermostat which is the temperature given by the internal sensor.
Changes to v3.0.0.8
- fixed icons for remote sensors
- fixed copy/paste of actions
Changes to v3.0.0.7
- fixed problem with remote sensors devices key (if you had installed version 3.0.0.6 previously you need to delete the devices for remote sensors, and then install and start the new version)
- added icons for sensor occupancy device, and root sensor device
Changes to v3.0.0.6
- added support for remote sensors
Changes to v3.0.0.5
- Fixed refresh of access token
- Avoid error when thermostat name is blank
- Fixed problem when setting low and hig setpoints.
Changes to v3.0.0.4
- Fixed problem with AutoHome and AutoAway event type missing
Changes to v3.0.0.3
- Fixed HSTouch integration / thermostat API
- Added "Current Program" device and moved confort controls to this device
- Added "Hold Action For" setting in the config page
Changes to v3.0.0.2
- Added "Send Message" action
- Added controls on the root device to resume program and for each comfort setting
Changes to v3.0.0.1
- Fixed problem with DehumidifierMode field
- Added icons for humidity and temperatures
- Fixed fan hold
Changes to v3.0.0.9
Changes to v3.0.0.8
Changes to v3.0.0.7
Changes to v3.0.0.6
Changes to v3.0.0.5
Changes to v3.0.0.4
Changes to v3.0.0.3
Changes to v3.0.0.2
Changes to v3.0.0.1
