On the guide i read:
But where I can set "the Output Time device for the given pin"?
Output: Outputs can be controlled in the following way:
On: Turns the output High
Off: Turns the output Low
Blink: This will Blink the output on and off at the time set by the Output Time device for the given pin
One Flash: This will Set the Output High then Low using the time set by the Output Time device for the
given pin
given pin
