Go Back   HomeSeer Message Board > Thermostat / HVAC Plug-ins > Thermostat / HVAC Discussion > HomeSeer HAI Omnistat Plug-in
HomeSeer HAI Omnistat Plug-in Discussions related to the HomeSeer provided thermostat plug-in for HAI thermostats. These plug-ins will eventually replace the current script-based thermostat support.
Old May 30th, 2013, 10:46 AM
acromion acromion is offline
HS3 Support
I just tried the HS3 beta and to my great surprise, there is a plugin for the HAI Omnistats. I'm both shocked and thrilled. Thanks to the HS folks who put that in.
At this point it is quite basic but it supports setting the mode and the heat and cool set points. Those are the essentials.
I would love to be able to set the humidity as well and push the outdoor temperature, but perhaps in time.
Old June 14th, 2013, 01:32 PM
mnsandler's Avatar
Insteon Overlord
thanks for the info.
what hai stat model are you using with this new plugin
Mark
HS3 Pro 3.0.0.368
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon 3.0.6.23 (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire | RFXCOM | NetCAM | MyQ | BLRadar | Jon00 Charting
Old June 14th, 2013, 01:34 PM
I'm not actually using it at all. I just installed the plugin for it and played around with it a bit on my test machine which isn't actually connected to any hardware. If anyone gives this a try, I'd like to know about it.
Old December 10th, 2013, 04:14 AM
snowboarder snowboarder is offline
Angry
in homeseer plugins i see there is a version 3.0.0.4 update
when i upgrade i only get 3.0.0.3 (Wrong file in the updater ?)
HTML code is On
