Go Back   HomeSeer Message Board > Thermostat / HVAC Plug-ins > Thermostat / HVAC Discussion > HomeSeer HAI Omnistat Plug-in
HomeSeer HAI Omnistat Plug-in Discussions related to the HomeSeer provided thermostat plug-in for HAI thermostats. These plug-ins will eventually replace the current script-based thermostat support.
Old May 27th, 2015, 05:16 PM
email68 email68 is offline
How to display the outside temp on HS3 plugin?
On the HS2 plugin for HAI thermostat you could enter an outside temp variable that would show up on the thermostat. How can I do that on the new plugin for HS3?
-Tim
HSPro - 3.XXX - Dell mini W7 x32
Way2 Call
Elk M1 Gold
UPB HAI switches
HAI RC2000 Thermostat
Old June 9th, 2015, 06:37 PM
No way to do this?
Old June 11th, 2015, 05:54 PM
Kirby Kirby is offline
If you use the free alternative plugin that I wrote, you would specify the HS device that has the temperature using the configuration screen.
Read about it at http://board.homeseer.com/showthread.php?t=174446
Old June 11th, 2015, 05:58 PM
Thanks. I actually just found it an hour ago and installed it already. It looks great! Thanks. I was trying the Day, Night, Away, and Vacation modes. I couldn't seem to get them to work. I have an RC-2000.
The modes are changing, but the set points are not.
Old June 11th, 2015, 06:10 PM
Since you have an RC-2000 Occupancy is supported natively by the thermostat. If it is not working for you, check the settings on your thermostat and make sure the program mode is set to occupancy.
Old June 11th, 2015, 06:11 PM
ok, will do. Thanks!
HTML code is On
THWR800 Water Sensor Temp Display aviatordave RFXCOM Plug-In (3P) 11 June 28th, 2012 12:25 PM
Display just temp in a virtual device jabrans WeatherXML 3 October 7th, 2010 02:17 PM
Temp Display axotis Script & Plug-In Development 12 July 10th, 2005 01:12 PM
HVAC control temp display JLehnert HAI/OnQ Panel (HS2) 1 July 24th, 2002 07:27 AM
