I still have some X10 devices in my configuration which I need to control inside of an Event. If the Action is setup as "Control a device", it does not work consistently. In addition to controlling X10 devices, this event is doing other actions which are in fact working. Note that I can navigate to the device on the device management page and turn the X10 device on/off without issue. However, if I simply change the Action to "Send X10" and just send the Device on/off command, it works every time. Is there an known issue with this? Is anyone else having this issue?
EVENT:"Control a Device" Not working, "Send X10" Working
Originally posted by cyber_jocky View PostI still have some X10 devices in my configuration which I need to control inside of an Event. If the Action is setup as "Control a device", it does not work consistently.
When you say it does not work consistently, what happens? Is there just no response from the device or does it do something besides what you expect?
Which X10 plug-in are you using ("X10" or "CM15A")?Mike____________________________________________________________ __________________
Are you trying to turn the device on/off or something else?
I have tried dimming settings and Only sending device on.
Can you post a screen shot of the event?
See attachment.
Poor phraseology on my part: When triggered, the event sends an email but none of the X10 lights turn on ( ever ).
No.
(X10) TI103
I'm stumped. I'm using a CM11 emulator (XTB 232) and send commands like these without any problem.Mike____________________________________________________________ __________________
