Can I verify that you are only seeing a crash when you enable the virtual device, can you otherwise use the tag editor? E.g. if you create a tag and set rules, hit save, do those rules exist if you come back to the config page?
Im actively tracking this down, but since i have not been able to reproduce it, I'm currently adding more logging and trying to find cases where linux/windows or potentially other common modules on the system can be generating a case I am not expecting...
