I searched through the threads regarding SkyBell but mostly just found general discussions which door bell is better. Hence I assume there is still no integration with HomeSeer (or an API that I could use) so I can access the video stream, trigger events when they bell is activated, etc. If there is then please let me know.
SkyBell HD Integration
Originally posted by mulu View PostI searched through the threads regarding SkyBell but mostly just found general discussions which door bell is better. Hence I assume there is still no integration with HomeSeer (or an API that I could use) so I can access the video stream, trigger events when they bell is activated, etc. If there is then please let me know.
Iftt can only detect motion & doorbell and transfer actions to hs3.
You can also trigger skybell recording from ifttt.
The bad side is you cannot reach the videostream, video is recorded as normal in the app.
https://ifttt.com/skybell
You can also create your own applets to connect with HS3Please excuse any spelling and grammatical errors I may make.
Tasker Plugin / Speech Droid
Tonlof | Sweden
Did anyone ever get this working? I setup an IFTTT integration to alert homeseer when the SkyBell is pushed (and sound a dome siren in the basement, where you can't hear the main doorbell), but the alerts from IFTTT always seem to come in between 5 and 30 minutes after the bell was pushed...
I never got this to work. If I did get a notification at all then it was extremely delayed. IFTTT blamed SkyBell and SkyBell blamed IFTTT. I did get it to work using stringify. It worked for more than half a year but currently I am having issues with it not working at all. It keeps on losing connection with SkyBell.
Well, I tried to get this working again and IFTTT still is pretty much unusable. Then I tried stringify but that service is gone. So I am still stuck with a doorbell that can't ring a chime because it doesn't integrate with anything than IFTTT and that implementation for any practical purposes is useless... If you have a solution please let us know.
mda, what dry contact module are you using?
Originally posted by mulu View Postmda, what dry contact module are you using?
Originally posted by mulu View Postmda, so how exactly did you wire this inline with the skybell. Any schematics would be helpful.
I also have a 10 ohm resistor in my setup because I don’t have a chime box. My actual wiring is a bit hard to access (I did not do the wiring) so I’m not sure if I can get at it, but I will try.
